2002 Oldsmobile Aurora Logo
Posted on Aug 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Olds Aurora.All interior lights are out. Found blown fuse.
All interior lights are out. Found blown fuse. Thought about checking door switches but can't find them any suggestions?
Joseph Howard
Level 3:
  • Master 753 Answers
  • Posted on Aug 23, 2009
Joseph Howard
Master
Level 3:
Answers
753
Questions
0
Helped
296893
Points
2162
Your Interior lights share a fuse with alot of other circuits and if I remember correctly the switches are built into the door latches.On some of the models the cigerette lighter is on the same circuit and if your element is bad it can short out,also you could check wiring between doors and body to see if any rubbed thru.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
783
Points
Do your power windows or mirrors work? I had similar problem where no interior lights would work, and only the driver window and mirror worked. Under the drivers seat about 6 inches behind where wires for the seat go into the carpet, there's a wire harness under the carpet. And in that harness of wires there's 4 wires clipped together and its wrapped in tape. Those wires are the serial cables that allow each door module to talk to eachother. Unplug it and look for corrosion. If there is, cut the plug out of there and re wire the wires together so that all wires touch together. Now try your lights and windows. It's a common problem, especially if you have a sunroof because the drain holes get plugged and water sits under the carpet causing corrosion.
Radio won't shut off after you open drivers door on a 1998 Olds Aurora. If I open one of the other 3 doors, radio shuts off ?
probably a bad or dirty door switch on drivers door, this can also effect interior lights not coming on when door is open
2answers
Diagram removal interior light 2008
best thing to do is check all your fuses. Just remove each fuse, look to make sure its good, then replace it. you don't want to mix them up, just look at each one to make sure its good. You might find fuses that were blown that you didn't even know you had. Here is a picture to show you the difference between a bad vs good fuse and what your looking for:49362d30-a297-476d-a02d-86ff64ed542e.jpg
My first thought was a blown bulb so i would check your bulb first, and you might want to check to see if the light switch is faulty.
Interior lights and tail lights don't go on for 2002 nissan sentra
you most likely have blown 10amp fuse for tail lights in the fuse box under the hood as far as tha tail lights go. turn your lights on and check your tail lights along with the plate lights. plate lights are on the same fuse as the tail lights. there is a fuse box by the battery which has tail light fuse in it. the lid of the fuse box is showing location of fuse. as far as your interior light goes, make sure that you have the switch in "door" position or it will not come on when door is opened. or just put it into "on" position to see if it comes on. but turn it off or put it back to "door" position/middle seting or your battery will drain down.
2answers
2002 Olds Aurora, the gas cover release, the trunk release, and the homelink all stopped working at same time, which fuse is it?
You'll have to test each fuse with a tester that lights up when a fuse is bad and it is powered if you can't find the sticker that has the fuse locations and guide for the abbreviations.
2answers
Trunk release switch does not work
1) check trunk fuse
2) check if there is voltage at the trunk latch and that you can hear the solenoid at the latch activate.
3) if voltage present and solenoid does activate. Try lubing the latch. May be binding.
4) voltage present, solenoid activates, latch lubed. trunck still does'nt open. replace solenoid
1helpful
Headlights and door locks not working
Fuse is probably blown out. Replace fuses for respective functions. Find the fuse box: might be in engine near battery or below steering wheel. open top and check for blown fuses. Try replacing if blown fuses are found. If all fuses are OK then it is very unlikely that all the bulbs are blown.
Interior Lights stay on
number 8 controls the courtesy lights, but if interior lights stay on check door switches
2001 Aurora - blows only 'warm' air
Your problem is either a clogged heater core, or the air temp control blend door actuator, in order to check for a clogged core feel the heater core hoses in the eng compartment, they should both be hot, one a little hotter than the other, if they are the core is ok and the blend door actuator needs to be replaced.
95 olds aurora interior lights dont come on anymore
Replace fuse under the back seat. Look in your manual, look in the fuse section and it will tell you which fuse it is exactly
2helpful
2answers
2002 jeep liberty - limited - electrical problem
If yor liberty is a 2002 to 2004 it is very likley that the wiring harness is pinched under either the drivers or passengers seat. you need to remove the seats (its only 4 bolts) and lift up the carpet and look at the harness that runs under the seats. I have seen this many times before.By the way i am a Jeep master technicain and have been for 15 years.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
