Question about Logitech Z-5500 Computer Speakers
No sound from left rear speaker
Hey, I've got this problem when I listen to music, There is sound in every speaker except for the Left Rear one. however when run the systems test, there's plenty of sound. I've tried to several different media players; Winamp, WMP, VLC, Itunes etc.
my sound card is a "Realtek AC'97 Audio for VIA (R) Audio Controller"
  • 1 more comment
  • JasonMason Dec 08, 2007
    Front and back speakers work when using radio mode, but when using cd, mp3 or usb only fron two speakers work.
    model KD-G635
  • k_Rich May 15, 2008
    yeah i got the exact same problem
    my left unit doesnt work and when i move
    the center of sound over to the left it preety much
    stops playing but the right sound and center is perfect
    i tried toyin with the back adn they're perfectly connected
    help??
  • drewing Jan 07, 2009
    I only use WMP for music. The surround works great on other programs I've used for DVDs but never has worked so great when listening to music in WMP. I just turn the surround down because I think wmp just doesn't understand it. Sounds just fine then.
  • 38 Answers
Speaker connectivity problems
get for repair
or trying installing audio driver again
Posted on Dec 04, 2007
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
Left rear speaker has no sound
exchange wires from one to other , switch speakers
Aug 29, 2014 | Bose Audio Players & Recorders
I cannot get sound from Insignia Speaker ND-POS20?
Speaker Placement Before shopping for speakers, try to imagine where you're going to put them in your room. Speakers can be placed on floor stands, hung on wall brackets, or placed on furniture. Subwoofers typically sound best in room corners or near the left- or right-front speakers.
The front three--left, center, and right--speakers usually sound best when positioned with their tweeters elevated to the same height as a seated listener's ears. In any case, try to keep the center speaker near the same height as the left and right speakers.
You can place speakers on shelves or on/in a low cabinet or entertainment center. Some speakers are better suited to this arrangement than others. "Acoustic suspension" sealed satellites are the most appropriate. Next best are ported speakers--as long as the ports are located on the front of the cabinet. However, speakers with rear-mounted ports won't perform at their peak when placed inside a piece of furniture.
As for the rear-channel surround speakers, they usually sound best when positioned three or more feet higher than the front speakers. However, high-fidelity DVD-Audio and Super Audio CD music will sound best when surround speakers are placed at the same height (ear level) as the front speakers.
Read more: http://reviews.cnet.com/speakers-speaker-systems/insignia-2-0-speaker/4505-6467_7-32912127.html#ixzz1MpaHsur1
May 19, 2011 | Insignia 2.0 Speaker System (2-Piece)
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-P4100
5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Feb 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
Logitech Z-5500 Computer Speakers Logo
383 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
