Question about Hoover HWF5513E Front Load
Dryer gets hot but doesn't dry well
Hoover front load washer dryer. Dryer gets hot but does not dry very well. We had someone out before who unclogged something (dog hairs) is this something I can do myself? Where's the clogged vent? Took top panel off but couldn't see it.
I think the engineer showed me it when he came a few years ago, but sadly can't remember what he did.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 990 Answers
Restricted air flow...either vent or wheel that moves the air. Try taking hose off of where it goes outside and just let it run like that and see if clothes dry faster. If so you need vent cleaned.
Posted on Oct 06, 2017
gittos73
  • 244 Answers
SOURCE: Hoover WDM120
this will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Posted on Aug 22, 2007
  • 183 Answers
SOURCE: 3135 Dryer Broke
If you remove the top there is a thermal fuse on the dryer heater duct, it appears this has blown, on some versions this is resettable, you will see a small button on a thermostat, push it in if it makes a suttle clip it has reset. Regards Advisor
Posted on Sep 01, 2007
SOURCE: Hoover Ultracare 1600 - Dryer not working
Check the duct work see if it is clogged up with lint.  Everything you read tells you to clean it out, but how many of us do it?  I just had the same problem with my duet dryer and when I went under the house to check, the duct was clogged up with lint and works like a charm now.
Posted on Jan 01, 2008
  • 1294 Answers
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 26, 2008
SOURCE: Draining issues
I just fixed a similar problem on my Samsung WF337 The machine was making a grinding noise during a wash cycle. After entering 'service mode' (see the "Washing Machine Technical Information booklet that came with your machine) and testing the drain pump operation I determined that the pump was the source of the noise. Eventually I found that a nickel had worked it's way into the drain pump. The manual does not address how to access or clean the pump so I thought I would post instructions.
  • Unplug the machine and turn off the water supply.
  • Remove the silver back panel by taking out the two phillips head screws, pushing the panel up, then pulling out on the bottom.
  • Under the tub, you will see the pump with two hoses attached. The black hose is the inlet from the tub and the white hose is the outlet to the standpipe
  • Using a cup and/or a towel to catch excess water, remove the hoses by squeezing the spring clamps and sliding them aside (slip joint pliers make this easier) then pulling the hoses off of the fittings on the pump.
  • If you need to take to pump out: Remove the three bolts (12mm hex head). I used a 1/2" drive ratchet with a 6"extension.
  • Unplug the power connector from the pump.
  • You can now lift the pump assembly out of the machine and remove any obstructions. To get the coin out, I had to shake the pump a few times and reach in with my finger to dislodge it.
  • And as always installation is the reverse of removal. Don't forget to reconnect the power cable to the motor and turn the water supply back on.
Posted on May 03, 2008
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
cheers
Aug 30, 2017 | Hoover Washing Machines
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Our Hoover Washer Dryer HW130M has stopped drying on the Tumble cycle. It continues to turn and dial turns to cmpletion but doesn't seem to heat up. Only realised as days cooler and not been using outside...
Yes could be the element but there is also a reset button for the element, designed to trip out if ever gets too hot. Remove the top of the machine and button should be clearly visible. Try this first before committing to a new element
Oct 05, 2009 | Hoover HW130M Front Load Washer / Dryer
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Jan 01, 2008 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
3135 Dryer Broke
Nov 12, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hoover HWF5513E Front Load Logo
101 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
