Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Streaks on Faxes sent.
Is this a problem at my end or a problem at the receiving end? If it is a sending problem, how do I fix it?
  • 2 more comments
  • rugratrat Dec 04, 2007
    Its on our end. Someone else said the copy has a black streak running through it. Help!
    Let me clairify, it does not happen when I copy something, only when something is faxed, at the receiving end.
    • no black streak when coping,
    • Black streak only when something is faxed on the receiving end.
    Yes, it has happened to multiple receivers, so its our machine.
  • 56 Answers
Hi Well it depends ? If you make a copy of the original thru the ADF do you see any streaking? If not then its' on the receiving end. Thanks
Posted on Dec 04, 2007
  • 1 more comment
  • WILLIAM MONDY
    WILLIAM MONDY Dec 04, 2007
    OK, The black streak when the person is making a copy are they using the flatbed or the adf? More than likley there using the ADF if there getting black lines. Now what you can do is open the ADF cover and clean the scanner glass usually buildup will get on there.
  • WILLIAM MONDY
    OK so its seems the problem is the receivers end fax. Have you tried to send a fax to another fax machine? To see if it has the same issue?.
  • WILLIAM MONDY
    Ok you can open the ADF and clean the glass more than likely there is something on the scanner adf glass that's causing this issue. You can use windex or and a soft tissue to clean the glass.
Faxes being sent with major streaks
Open the cover where the documents are loaded and clean the thin glass there. It may have some white out or dirt on it.
Jan 20, 2012 | HP 640 Inkjet Fax Machine
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Its giving me a pls open cover offline screen and it wont send any faxes i might be stupid this maybe is normal or simple but when the machine is warming it gives out a wicked screeching noise
Hi Fax machines are one of the oldest ways to send document information over a telephone line. Before e-mail became the most popular, and more efficient way to send documents, the fax machine was king. With time, fax machines have become sophisticated machines capable of many functions. No longer found only as a stand-alone machine, fax machines are included in copiers and printers. Faxing can even be done through computer software to a receiving fax machine or printer. So with such a complex machine there are several things that could go wrong. This article teaches you some basic troubleshooting steps.
    Fax Quality
  1. If the faxes you are receiving are too dark or light, or ruined by streaks and splotches, play around with the darkness and density settings on your machine. Send a few test faxes until the quality looks good on your end. If the faxes continue to come out poorly, the problem probably lies on the sender's end. If you are the sender, and your documents are coming out badly on the other end, try cleaning the sensors of your machine with a damp cloth.
Aug 09, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
62 people viewed this question
old marine
old marine
