GE WHRE5260E Top Load Washer
Problem for GE WHRE5260E Top Load Washer
GE Washer spins, gets off balance and 1 dampening strap falls off
By mike_tinafri on Aug 23, 2009
We are able to hook the back right hand side corner back on but it will fall back off again. question is do we replace the straps or is it something else. If we do replace it or need a better way to get it back on then what are those directions? currently we take the front panel off and my husband lies on the ground and I hold up the tub while from the ground he puts it back in place.
Best Solution
posted on Aug 23, 2009
Very Helpful)
hiltonjug
Rank: Guru  GE Washers & Dryers  Expert
Rating: 92%, 219 votes
Replace the round black rubber straps. There are 4 of them, one in each corner. These help the drum from going crazy. Also, if you don't replace them, you will end up cracking the outer tub. It will crack when it hits the side panels. This will cost you more to fix than buying a new machine.
Please rate solution if helpful.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for GE WHRE5260E Top Load Washer
Questions and Unsolved Problems for GE WHRE5260E Top Load Washer
Do you recommend GE WHRE5260E Top Load Washer?
Answer
Answer
how do you get the drum out of your washer? there is 2 drapery hooks between the drum and the wall.
Answer
we have a GE model #WHRE5260E1WW that stops in mid cycle and must be started with the push start/... (More)
Answer
GM whdrr418e1ww need to remove top. I don't see where it attaches. It sounds like a hose is... (More)
Answer
When in spin cycle, it makes a loud noise, like a roaring type noise. What is the problem?
Answer
how do you pull the drum out of a washing machine
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Sedona, AZ
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
