Washing Machine Fills but does not wash,spin or pump
  • 2 more comments
  • gwclark May 08, 2008
    will not spin -pump fill only
  • susancart May 21, 2008
    same problem, only makes a little noise, won't spin, but I can spin it by hand. fills with water
  • Anonymous May 27, 2008
    Me too POS machine
  • John Zingerella May 17, 2009
    After five years of reliable service. Washer will fill but timer will not advance and washer will not spin. There is a slight humm, but no action. It will drain.
    New Friend:
  • 33 Answers
Could be a couple of things. First of all, check that your filter is clean. Normally located at the bottom front of the machine, behind a flap. some are hand tightened, others need a screwdriver. If it is difficult to remove, then it will be jammed solid, just try to loosen the fluff. Be prepared tor water to escape. Lots of towels, or something to catch it in, should be kept handy. If this does not solve the problem, or your model has no filter, make sure the drain hose is not too high. The top of your waste outlet pipe (the bit where you put the corrugated grey water outlet pipe) should be no higher than about 2/3rds up the machine height. If it is, try lowering it (even hold it above a bucket just to check, before you get the hacksaw out).
Posted on Feb 06, 2009
Bosch classixx washing machine won't spin. It fills up and washes - does not drain, does not spin. I have manually drained it and checked the plug - nothing was trapped. Ran the machine again - fills,...
Check the filter if clogged clean it or if not check if pump is functioning. Sometimes pump can' work bse of coins stuck in it or rubber bands from pockets.
Dec 08, 2017 | Bosch Washing Machines
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
Fills with water, won't spin water out, get F50 message
heatman101
Aug 28, 2011 | Washing Machines
My kenmore washer fills but wont pump the water out. it washes and spins, but i have to **** the water out with my shopvac. the drian hose is not clogged or kinked. could it be the water pump?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 14, 2011 | Washing Machines
Washer fills with water but does not spin or drain.
heatman101
Apr 03, 2011 | Washing Machines
Washer fills and washes but will not spin or drain
heatman101
Dec 15, 2010 | Whirlpool Washing Machines
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but doesn't drain or spin
heatman101
Sep 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
It fills w/ water,and empties it wont spin ,or agitate
heatman101
Sep 06, 2010 | Washing Machines
Washing machine fills with water ok but won't agitate completely, will empty the water but will not spin.
heatman101
Aug 29, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
