Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Clearing the buffer
Is there a way to clear the buffer so that we don't have to print unwanted faxes?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Screen says memory overflow, what do I do?
You have Fax's in the Buffer that need to be cleaned out and or Printed. Clear Memory will do both but if you have Fax;s that should be printed, then you need to print your Que..
Jun 19, 2014 | Toshiba Dp-80f - *220 Volt Commercial...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
How do I clear the memory of received faxes without printing?
Try clearing the DRAM( Document memory.) Do the following.....
Press PROGRAM, *, G...(display should say "DRAM Clear".)
Press ENTER.
That should do it.
Nov 17, 2010 | Muratec F320 Plain Paper LED Fax
How do I clear the "received" memory without letting the machine print every received fax?
Try clearing the DRAM. ( Document memory.) Do the following....
Press PROGRAM, *, G ..( Display should say DRAM Clear.)
Press ENTER.
That should do it.
How to clear fax memory?
Remove AC power from the unit for 10 seconds. You can simply pull the cord from the back of the machine. This will clear the fax memory buffer. When the unit restarts, it will want to print a one page "power down report" and will show that the buffer has been cleared.
Nov 06, 2010 | Panasonic KX-FP121 Plain Paper Thermal Fax
How do you clear print buffer on Genicom 4440XT printer?
The buffer on the 4440XT can be cleared by powering the printer OFF and then back on again.
You may however find print jobs are held in the spooler on the computer system and will simply reprint when you turn the printer back on again, you will need to check the spooler on the system also to delete any unwanted print jobs.
Nov 17, 2009 | Tally Genicom 4440 Printer
Receving large unwanted faxes
Please rate my solution. Hope this resolves the problem.
According to the manual one of the things that can cause this is if the data cable (USB) was disconnected from the printer while the job is printing. Press the Cancel button on the printer, that should clear the memory. Also make sure you don't have print jobs in the queue if the printer is connected to a pc.
Manual can be downloaded at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Aug 28, 2009 | Brother IntelliFax-2820 Laser Fax
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
PRINTER PROBLEM where is my hp tool box? I HAVE INSTALLED NEW INK CARTRIDGES AND NOW MY PRINTER PRINTS OUT A LOAD OF PRINT I CANT UNDERSTAND. THANKYOU
Try double-clicking on the printer in the Printers and Faxes folder and clear any pending jobs. Turn off and disconnect the power cable from the printer for a few minutes to clear its buffer. Keep the paper removed from the tray during this process and only re-insert it after the printer has stopped attempting to print. When the spooler and buffer are cleared normal printing should resume.
Nov 11, 2008 | HP Deskjet 6940 InkJet Printer
Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
May 05, 2008 | OKI MICROLINE 321 Elite Matrix Printer
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
85 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
