Question about Shuttle XPC PC Desktop
Shuttle will not start from power on button-
My shuttle would not turn on most of the time; occasionally it did, at times way after I had pressed the ON button. Checked power supply voltages- all seemed ok. Supply comes on if I short PS ON ( green) atx pin to ground; if I remove the ground, it goes off. I checked the switch for operation at the header- it seems to be operating as momentary switch per its function. Once booted, all seems normal. The HD light stays lit if I turn the PC off. I am thinking there is a break in the connection from the switch header and the ATX PS header.Not sure the best way to proceed from here. I love the little PC- it has served me well for years with no problem.
Any ideas to try?
  • mitrabbit Dec 05, 2007
    I am not to sure I understand the solution. Is it to solder the ground line at the switch header to ground? Which ground line needs to be connected to the system ground? I think you might be right that since the switch apparently does make closure, it must not be getting the power supply "green line" to ground. Perhaps the ground on the mother board opened.
    thanks for your suggestion- will see if it works.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Mitrabbit
Happy Holidays
well, is a problem with lines, that you must change, and welding the ground to the line should fix that in your particular case. but carefull not to weld much,the ground line.
good luck
Posted on Dec 04, 2007
Does anyone know how to get my shuttle to start up right when the power comes on?
Yes, rewire the power supply and short the power on button. Then stand back and watch the fireworks. There is a reason why the system is set up like it is. So just spend a bit more energy and press the little button on the front and wait the extra half second for it to start.
Jul 09, 2012 | Shuttle XPC SS56GV2 (XPCSS56GV2) Barebone
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Shuttle has been working fine for about 4 years. Then it would be slow coming on, maybe boot up 20 mins after pressing the on button. Eventually refused to come on at all. I replaced the power supply and...
Change your BIOS battery.
I have an old Shuttle XPC sn41g2. It's been running almost constantly since it was new. About a year ago it started to be difficult, it was difficult to start and sometimes I had to try several times before it started. At the end I had to disconnect and reconnect the mains supply everytime i had to reboot the PC. Then one day I discovered that the prosessor was running at the lowest standard frequency so I went to the BIOS to set it right, did so and rebooted, and the prosessor stil wouldn't run right. After some thought I changed the BIOS battery, went to the BIOS, resat all settings, then it rebooted normally and since it has been running like new.
Jan 02, 2010 | Shuttle XPC PC Desktop
Shuttle fault
If the printer detects the shuttle moving at the incorrect frequency, it shuts down the shuttle and attempts to restart it.
If the shuttle still operates incorrectly after three consecutive attempts, the Printer goes Offline, and the Shuttle Fault message is displayed.
Press the Clear button, then put the printer back Online. If this doesn’t work, turn the power switch off, then back on again.
If the error is still seen after performing the above actions, check there are no paper jams , labels etc or ribbon jams that may prevent the shuttle moving correctly. Also check the Patten gap to make sure it is not closed too much.
Then you may need to change shuttle components
Dec 04, 2009 | TallyGenicom 6306 Matrix Printer
Format error on my nw-505
be sure to format using the MENU mode on the unit and ADVANCE MENU then FORMAT Press and hold the search/menu button for half a second in stop mode. The menu screen is displayed. Rotate the shuttle switch to select "Advanced Menu" > and press the play/stop button to confirm. Rotate the shuttle switch to select "Format" and press the play/stop button to confirm. Rotate the shuttle switch to select "OK" and press the play/stop button to confirm. "Formatting..." blinks and start formatting. When formatting is complete "complete" is displayed.
This is how i get rid of the problem "Format Error".
May 11, 2009 | Audio Players & Recorders
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Shuttle XPC - fan on the back does not stop
I would suggest you have a fan with faulty bearing
and i thing the power supply could want changing
Sep 01, 2008 | Shuttle first SFF barebone with the power...
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
Shuttle XPC PC Desktop Logo
1,232 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
