Home | Heaters | Hydronic Boiler rel...
Heaters
Problem for Heaters
Generic problem for all Heaters
Hydronic Boiler relief valve problem?
By TOMMYVOGT on Dec 03, 2007
Releif valve is lifting when temp is up, but not when cold ?
Where should I first look to solve problem?
Same Problem
Nov 09, 2008
-   My pressure relief valve keeps leaking when system pressure is above 20 PSI. I tried lifting it quikly and releasing it to clean it but I can't get to stop leaking.
Should I change the pressure relief valve? or should I change my old expansion tank to a more modern pre-pressurized tank? -   Gio123
Best Solution
posted on Dec 04, 2007
Very Helpful)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 382 votes
Check the pressure guage. Typically the pressure in a water boiler should not be more than 20 psi. If you are approaching 30, the relief valve is doing it's job. I would replace or adjust the automatic water feed if the pressure is high. Always replace the boiler relief valve. Tap on the expansion tank, it should sound hollow. Replace it if it is full of water. If you have one of the old expansion tank that has no bladder in it, drain it.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
how can you buy things for less than what they ask for?
Answer
What is the safest & most cost effective patio heater
Answer
hot water heater is making a moaning noise in the night.pressure is ok, rads have been bled... (More)
Answer
temperature will not rise after to reach desired temperature after having turned on for a long... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
