No matter what kind of mic or input jack I've used, the sound is either dirty, weak, or over-modulated. I've used everything from XLR mics to cheap computer mics and I can't get noise-free sound and volume at the same time. I've taken it through a sound board and plugged straight in.
There is a low-level hiss and a high-pitched whine. I'm not looking for broadcast quality at this point, just something decent for demos.
Help!!!
Comments:
Aug 31, 2009
- Since this posting I have fixed the problem. It took a lot of tweaking, but basically it was that the XLR mic didn't have enough power behind it and trying to compensate with the program and the computer was making matters worse.
sounds like you are using the wrong fx... acid studio comes with some professional plug ins. use those instead. they have one that allows you to take background air, and noise out of your recording it's call background gate. none if this may make any sense to you so i have pictures.
after you click your green FX icon next to your track don't use the features below. go to where the read arrow is pointing. click that green fx icon instead.
click the all folder on the left side. on the right side will appear a list of plug in's/special effects (red arrow is pointing to the list). their is one called a noise gate use that to remove background sounds and air.
they have other features like chorus and reverb... these plug in's do great. i hope this helps.
you can add whatever effects you like on one track and save the effects as a name. that way you can add it to every track and don't have to go through the whole process of selecting the same fx for each track. i really hope this helps i'm not very good with explaining things. ha ha ha.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony Acid Music Studio 7 Full
every time i try to lay a track over another it has a lag how do you fix it? like i record the...
(More)
every time i try to lay a track over another it has a lag how do you fix it? like i record the drumbs and then try the guitar and try to play with it i am on time and then play it back it has a lag
I am setting up a drum pattern using the inline editing and using the draw tool to put the beats on...
(More)
I am setting up a drum pattern using the inline editing and using the draw tool to put the beats on the timeline. Once I have put some beats on, when I try to add more beats in between the ones that are already there, it moves the beat to the right over instead of putting a new one in, so I have to keep moving them over if I want to keep what I already had. How do I get it to add beats in without moving others?
