Question about Yamaha HTR-5730 Receiver
My reciever turns on for about 4 seconds then clicks off..
I have checked wires, even tried to reset it. It stays on for about 4 seconds then clicks off. Any help would be AMAZING!!! thanks Rachelle
  • pbjudge Dec 07, 2007
    I have the same problem with mine. I recently bought it and it worked good for about 3 weeks then it started doing this and I can't figure out why. Anybody?
  • 833 Answers
First, unplug and replug in the unit to reset everything. Second, check each cable for a short using a multitester. Each speaker cable should show a few ohms of resistance. If either open or a dead short...there's the problem. Not it? Get service.
Posted on Dec 28, 2007
I recently got an iPod touch, and realized you have to have Wi-Fi. So I bought a Belkin router. Now I'm having trouble reseting it. Every time I try to reset it, the light just stays red and doesn't appear...
first unplug everything then wait 30 seconds then replug everything and try it if that doesnt work there could be a power cord problem in which case you would need a new one because of the wiring system inside will not work correctly after a wired has been frayed or damaged.
Jun 22, 2010 | Belkin (F5D5231-4) Router
System turns on but only hear feedback fomr speakser no sound
do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
May 22, 2009 | Pioneer VSX-D409
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
No Power From My Reciever
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Feb 21, 2009 | Philips HTS3450 System
SRS light on 1997 acura CL
1.bend a paperclip into a u shape. 2.disconnect the yellow plug in your fuse box under the steering wheel and insert the paperclip into the plug that is now hanging there to complete the circuit.3.turn the ignition on and the srs light will stay on for 6 seconds, then turn off.disconnect the paperclip within 4 seconds after that and the light will come back on.4. reconnect the paperclip within 4 seconds and the srs light will turn off again.5.within another 4 seconds of it going off, disconnect the paperclip and the light will blink letting you know that you have completed all the steps right. you can also use some speaker wire
Feb 01, 2009 | 1997 Acura RL
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Yamaha HTR-5730 Receiver Logo
124 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
