Question about Sharp AL-1655CS Copier
Installed new drum
We are getting ink on the copy paper- looks like fish scales uniform throughout top to bottom also dark lines top to bottom. Needs to clean up the backgroud. How do we fix this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Posted on Dec 04, 2007
One thin line appears in the prints, close to the bottom. what should i do to correct the problem? and if the head needs to be replaced where is the cheapest place to buy?
When the head have lines , the problem is in the drum. The drum in that printer maybe is to expensive but you will try to get in ebay.
Nov 27, 2010 | Sony UPDR150 Thermal Photo Printer
Smudges on paper and ink is light when it does copy correctly.
It sounds like your drum unit needs to be replaced. Do the smudges look characteristically like a finger print? Technicians have a rule of thumb. Replace your drum, developer compound and general service the machine as often as you service your car. Assuming you do service your car as often as I do, it should be after every 25,000 copies. If the machine has never been serviced then its time you did.
May 25, 2009 | Sharp AR-5320 Black and White Copier
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
I'm suddenly getting uniform black lines on copies when using my canon pc 425 monochrome personal copier
remove toner cartridge, and look at the drum (on the bottom of cartridge). If there are toner streaks on it, it is failing and needs to be replaced.
*please rate me :)
Mar 26, 2009 | Canon PC-425 Color Copier
2 lines down the right side of paper - sharp 1641 CS copier
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Dec 11, 2008 | Sharp AL-1641CS Laser Digital Copier
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Copies have a dark shadow across the top inch of the paper.
You need to replace the drum unit to resolve the problem.
May 14, 2008 | Canon imageRUNNER 2200
Drum? glass? on faxphone?
try this take out drum( toner) clean machine see if there is a thin strip of glass on bottom inside the machine. make sure it is clean, this will give you black lines if dirty.
here is the manualit can guide you better, look for the troubleshooting and maintenance section
http://www.retrevo.com/s/canon+b640++manual?rt=tr&p=http%3A%2F%2Fwww.usa.canon.com%2Fcpr%2Fpdf%2FManuals%2Fb640_ug.pdf
good luck
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Sharp AL-1655CS Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
