Question about Onkyo TX-SR803 Receiver
Onkyo TX-SR802 sound stopped working
I have a question, my receiver stopped working, I left my house in the morning when I came back in the afternoon it was still on, when I tried to play a DVD there was no sound, I turned on the DVD and the reciever did pick up any sound(optical), I checked my computer that was connected to V3 and no sound either, checked the PS2 that was connected to V2 and nothing, tried the sound test and nothing, tried changing A-B channels and even radio and nothing at all.the lights are on but I can't hear anything and it doesn’t seem to pick the optical cable from the DVD. I checked the cables in the back and nothing, headphones dont work either. Any ideas?
  • 21 Answers
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Posted on Sep 03, 2007
  • 298 Answers
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Posted on Nov 17, 2007
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 06, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
Onkyo tx-nr808 sound stopped working
These units have a common problem with the firmware not being able to load correctly. Only way to really fix it is to replace the digital board - really expensive repair. Can sometimes be fixed by reheating Q3001, but this doesn't always work.
Nov 27, 2013 | Onkyo Audio Players & Recorders
Onkyo tx-nr509 no sound
check to make sure the speaker wire is not touching on the back of sterio or speakers. then shut off and turn back on. check the menu for speaker a and b and make sure it is turned on
Mar 13, 2013 | Onkyo TX-NR509
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR803 Receiver Logo
238 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
