Question about Mustek DV520T Digital Camera
Formatting memory card
How can I get started? It seems to be frozen
    Problem Solver:
  • 9 Answers
Formatting Memory Card
A new SD card shall be firstly formatted before use.
a.) Select (Format) to enter into property list.
b.) Select “NO” to cancel the formatting. Select “YES” and press (OK) to execute the
formatting.
c.) All the contents in the memory will be cleared after formatting.
About Memory Card
The external card supported by this camera is SD card.
To use a new SD card, you have to format it firstly.
Maloperation may cause damage to or deletion of the data recorded.
The loss arising from deletion of recorded data will not be the manufacturer's
responsibility.
Electrical interference, static electricity and failure of video camera or memory card
might damage the data in the card. Therefore, it is suggested to transfer the data to
your computer timely.
Never take out the memory card or turn off the video camera when reading or writing
the data.
Never put the card under high temperature or high humidity.
Never modify or tear down it.
Cheers.
Posted on Mar 12, 2009
Camera message is: memory card requires formatting : I chose the option to format and camera will start formatting then stops and this message pops up:please format memory card or put in new memory card. I...
Try formatting through the computer rather than from within the camera itself. Or, just open the card on the computer, select all, then delete. There's probably a large file in there somewhere that the camera just doesn't have enough ooomphh to move out.
Hope this helps. :)
Sep 29, 2010 | Cameras
When i am formatting my 2 GB micro sd card than formatting start but after some time there is a massage comes that unable to complete formatting, what is the salution of it?
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 12, 2010 | SanDisk 2GB microSD Memory Card
How do i format my sandisk 8gb m2 memory card to work with my sony ericsson w395as it doesnt seem 2 work when its in the fone ive tried formating it on my pc but must be different settings for the fone
hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
Mar 18, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
Camera needs (re)formatting is frozen can't do
Hello ^^
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
#3
#4
#5
#6
Nov 30, 2009 | Ricoh Caplio 500G Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
I cannot format my brand new memory card in my Kodak Easyshare.
The I would have to say bad card. Do you have another to try?
May 11, 2009 | Kodak EasyShare C360 Digital Camera
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
Formating the memory card for a samsung E250
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Oct 21, 2008 | Samsung SGH-D900 Cellular Phone
    SD card formatting
    I have to take the batteries out everytime i want it to unfreeze.
    Nov 20, 2007 | Cameras
    Mustek DV520T Digital Camera Logo
    177 people viewed this question
    Top Mustek Cameras Experts
    Mohamed Ismail
    Mohamed Ismail
    Steven Wander
    Steven Wander
    Marvin
    Marvin
    Are you a Mustek Camera Expert? Answer questions, earn points and help others
