Question about Sony DVP-CX985V Multi-disc DVD Player
Sony DVP-CX985V Disc Get Stuck And Jump Forward
I burn my disc, DVD-R/+R Memorex using Nero 7 & 8, and the DVDs get stuck for just a second and then jump forward. Sometimes the jump forward is just a few seconds and sometimes it maybe 30 seconds. This occurs in my DVP-CX985V Sony DVD player. The funny thing is that all 4x and below burn speed DVDs work fine. It is only with disc greater than 4x that the problem occurs. I have tried several different disc brands and I have tried setting the burn speed to 4x with a 16x DVD and still no luck! I have to to Sony tech. support with no luck. I would not mind using 4x DVD but, you can not find them anymore!!!
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: where can i get a manual from & can this machine be reprogramed to take region 2 dvds thanks ****
Click Sony Support to download instruction manual of DVP-CX985V and region code can not be changed in this model.
Posted on May 31, 2009
SOURCE: i have been advised that its not possible to hack
There is an coy in Switzerland that will do firmware change to multiregion depending on your model
Posted on May 14, 2010
SOURCE: Sony remote RM-DX500 not working with Disc
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Posted on Dec 24, 2010
Player says cant read disc 400 disc dvd player
wow nice machine try putting a lazer disc cl=eaner in it
Jul 01, 2011 | Sony DVP-CX985V Multi-disc DVD Player
Sony remote RM-DX500 not working with Disc Explorer 400 DVP-CX985V, but does work with tv. How can I program it to work the dvd player?
Oct 11, 2010 | Sony DVP-CX985V Multi-disc DVD Player
Where can i get a manual from & can this machine be reprogramed to take region 2 dvds thanks ****
May 31, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
BURNING DL DISC WITH NERO
G'Day,
I have the same issue with the LG GSA-H20L and the LG GSA-42N, but mine was with TDK DVDs.
I contacted LG Support and they told me that TDK disks are not recommended for use with their DVD Burners.
I asked them if there were any others they did not reccomend and they said no.
Going through my cupboard, I found Memorex Printable DVD-Rs that will burn OK.
I also tried Sony DVD+R and a generic brand, but they will not burn either.
I also found that these LG drives do not recognise Laser CD-R.
In short, for burning, try either Memorex, LG and some others, but don't try TDK, Sony or Laser.
Good Luck
Jan 13, 2008 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
Taiyo Yuden DVD-R DL discs not burning in Nero 6
Are you sure that you are putting in a blank disc? What happens when you put the disc inside the DVD writer? does it show up as a blank disc? This could be one of the reason for the multi session disc box getting greyed out.
Dec 26, 2007 | Electronics - Others
My sony dvd is powering off about one minute after I turn it on.
1. Press Display.
2. Go down and select Setup.
3. Move to the Right and Down to select Custom, Press ENTER.
4. Move down to the center box.
5. Move Right to select Auto Power Off, Press ENTER.
6. Change it to Off, Press ENTER
7. Press Display and you should be done.
Aug 11, 2006 | Sony DVP-CX985V Multi-disc DVD Player
Sony DVP-CX985V Multi-disc DVD Player Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
