Question about Air Purifiers
Cambell/hausfeld air compressor model# wl650102aj air compressor
It should pump up tp 120 psi but only goes to 80 and will not automatically come back on no matter what pressure drops to.
Frank
  • Anonymous Jan 04, 2009
    my compressor should go to 120psi but pumps up to 50psi and stays runing till i hit the off switch
Well currently dealing with a similar situatio with a Wl650102aj CH ocmpressor, in my case it was that factory bend copper tube that runs from the motor into the check valve on the tank, it was cracked, havn't been able to find a replacement yet, and bending your own will not work... as they must be stamped out, there is no way to really get that particular bend in them.
So that may not be your case, but I would be willing to bet if it's not pressuring up and the check valve is good, and your manifold isn't leaking... that your having the same problem
-rk
Posted on Apr 16, 2010
Looking for a break-down / exploded view of a Honeywell Air Purifier, model HFD-120 ?
Honeywell Air Purifier - problems - YouTube
? 1:22
www.youtube.com/watch?v=gWB121JIQMw
Apr 28, 2011 - Uploaded by Bill Golden
Overview of damage and possible fan problem with Honeywell Air Purifier. ... Honeywell QuietClean Compact ...
Oct 03, 2015 | Honeywell Air Purifiers
Ecoquest freshair - inside wireing
Black = phase white = Neutral , Strip yellow/green =ground
Aug 11, 2008 | Ecoquest Flair Air Purifier
New Honeywell hfd-120 purifier will not turn on.
If it is new enough it could be due for a warranty replacement. Otherwise, there could be an open fuse or a failed switch.
Nov 29, 2014 | Honeywell HFD-120 Air Purifier
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Gas spits back if I pump too fast, and the check engine light is on --maybe a vent is clogged--Help!
GASOLINE in the air filter is a serious fuel injection problem....to be honest....I have never heard of such a problem...air goes through the filter into the cylinder where it mixes with gas....to have gas spit back into the air filter.......exhaust valve stuck? Maybe intake manifold is leaking? Gas from the tank goes straight into the cylinder via the fuel injection hose...how does it get into the air filter is really a problem. .
Dec 03, 2013 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
Red light is on and off
compressed air is the best way to clean one, or a weed blower works also but not as good as air from a air compressor .oh do it outside never inside it's going to make a big dust cloud !. jay the pool pump guy in fl
Feb 03, 2012 | Sharper Image Ionic Breeze 3.0 Air...
Do you sell living air with ecotech products that have filters that you can rinse off? It is time consuming to go into the unit as needed to clean the inside.
You can wash the ozone plates off however i can't stress enough, THEY HAVE TO BE DRY when put back in. The back filter can be cleaned with an air compressor
Aug 27, 2009 | Ecoquest Breeze AT Living Air Purifier
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Air Purifiers Logo
708 people viewed this question
Top Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
