Computers & Internet Logo
Posted on Aug 23, 2009
Monitor wont read the harddrive
Manual
BigFatGeek
Level 1:
Scholar:
  • Contributor 32 Answers
  • Posted on Aug 23, 2009
BigFatGeek
Contributor
Level 1:
Scholar:
Answers
32
Questions
0
Helped
4128
Points
86
First (and I am sure you have already checked this), I would make sure all cables are connected and all power cords are connected. If the monitor comes on but there is no image I would try to use the buttons on the front of the monitor to adjust the brightness and contrast and see if this fixes the problem. If neither of these solutions work, then try a different monitor. If you try a different monitor and still it does not work, then something may be wrong with your video card inside your computer and either the video card will need to be replaced. Or you may need to buy a video card if the monitor plugs directly into the motherboard (big circuit board inside the computer). Hope this helps.
2answers
My acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Everytime i turn the playstation 3 on the screen says can not read hard drive and wont reset or turn off
The harddrive in your ps3 has died. Unfortunately the only way to fix this is to replace it. Any 2.5inch harddrive will do. Installation instructions below:
Trying to reload Windows XP on an emachine w3050 and wont find the harddrive. harddrive does show up in BIOS. so what am I doing wrong>
Go into bios and be sure the unit is set to boot to the DC/DVD when you boot up the unit.
clean the disk with windex - it helps to make it easier to read
I have a sony pcg-k45 and the monitor is dark some one gave it to me they let some one use it and his buddy opened it up to re place hard drive and now it has a dark monitor if plug a monitor it fine but...
Well, simply opening the harddrive cover and replacing the harddrive should not have caused the problem you are experiencing. You will need to systematically troubleshoot the issue and find the problem by the process of elimination. I would first "open it up" (see if you can find a service manual on line or at Sony detailing how) and check the cable connectors first, unplugging and then plugging them back in. Then see if it works. If not, read up on testing the LCD inverter and backlight. It will have to be one of these three.
I have a gateway solo 2500 with trying to use a samsung 40gb harddrive cdrom reads up but wont formate the harddrive why help please
The Gateway Solo 2500 model computer accepts hard disk drives up to 6gb. The system is not able to correctly read and use a 40gb hard disk drive.
I have a 150GB firelite i plug it into the computer which has vista but it wont read the computer will keep beeping until i unplug it S/N usbflb160
check the manual for installation procedure..
beepings are error problems it might be a power problem or a damaged harddrive..hope this helps! ITTech7574
1helpful
Xbox 360 hard drive wont read
Reformat it if that does not work it may be a faulty harddrive. And u may need to get a new one. better to lose a gamerscore than to buy anthoer harddrive. Good Luck
2answers
Won't load windows...
hi Lus;
What color do you have on the power button of your monitor? Check the VGA port at the back of your computer, how many VGA ports do you have? if you have 2, try the other port instead,
here is a VGA port:
http://www.google.com.ph/search?hl=en&q=VGA+port&btnG=Search&meta=
hope you see the images,
ill wait for your feedback
2answers
It works but doesnt read any discs
well the harddrive is corrupt same thing happened to mine. this happened because while you were playing a game or watching a film you probably moved the console which damages the harddrive but there is no way you can fix it you either send it to sony which would cost a fortune because its in america and there is a risk of it getting lost or damaged in the post or you type in ps3 repair in google and click on the first one.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
