Question about Kitchen Ranges
Gas Oven Flame Constantly on High
My gas oven flame is constantly on high regardles of whether the setting is turned down low. Can you advise the likely cause?
  • 640 Answers
I belive that the thermostat to the oven isnt working properly.The t-stat bulb sits inside the oven on the wall and this is what senses the temp in the oven.If its out of place or the t-stat is bad the oven will just keep heating.hope this helps let me know.HAPPY HOLIDAYS!!
Posted on Dec 03, 2007
My top [gas] oven will not heat. The ignitor lights. The gas strip has small blue flames lit along it. However, no matter what i turn the oven up to the flame will not increase.
Gas oven burners are usually a variable gas flow. When on high, the gas valve is fully open and the flame is high. As the heat increases in the oven, the flame reduces in size until the burner is running on whats called "bypass rate" or "maintenance rate" This is the smallest flame the burner can operate on without going out. I would suggest that the thermostat gas valve is faulty and not fully opening. It is also possible that the thermocouple may be faulty. This is a solid piece of wire which is usually situated in the flame path above the burner and connects to the gas valve and regulates the flame. It also triggers the gas valve to turn off , if no flame is present. I would try that first. A lot cheaper than a gas valve. In Australia, you have to hold a Gas service Licence to do this work.
Oct 02, 2015 | Kitchen Ranges
Very small flame takes like ten minetes for flame to get high
The reason the flame in the oven is so small and takes for ever to heat up is because the oven igniter is weak and can not open the gas valve very much so hardly any gas flows resulting in a low flame size. By replacing the oven igniter the flame will be full size and heat quickly.
GENE
Oct 16, 2011 | Sears 61301 Gas Kitchen Range
My Viking gas oven is slow to heat?
very likely the thermstat is defective, most likely the oven temperature proble
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
Gas oven
Its the flame failure device faulty (FFD)
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kitchen Ranges Logo
276 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
