Question about Cameras
KP20B Camera Do I need the Composite cable and SVideo cable both connected on this camera?
  • 3 Answers
If you want higher quality video, hook up the s-video connection instead of the composite video connection, but you'll still need the audio connection from the composites. So essentially, yeah.
Posted on Dec 04, 2007
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Connections for dvd player to tv
can be done 3 or 4 ways::need to look at outs on player and ins on TV.
HDMI; composite; s-video; RCA [please no]; RF [even worse]
look at what the player can output [normally all active at the same time]::find the highest resolution the TV can accept::get the proper cabling::hook it up::set TV to that input [usually able to name them {antenna, cable, hdmi 1-x; svideo 1-x, composite}
Feb 19, 2012 | Magnavox Televison & Video
Hmm.. I doubt you will be able to help me, and if you can, it won't be free, but here's my question anyway: any idea why when I try to connect an s-video cable from my harman kardon avr 130's Video 1...
Well, use the "Monitor Out" jack on the receiver, as that is what it's designed for.
Is there a jack labeled "Video 1 Input" or only "Video 1 Output"? It could be that the Harmon Kardon folks have a weird way of labelling so that "Video 1 Output" is actually an "input" to the amp that is then fed thru the "Monitor Out" jack. It will take some experimenting on your behalf. Some units will also NOT take an input or output thru the S-Video IF you have a composite cable connected to the (yellow) composite video jack for that same point, so make sure that is disconnected if you want to use the SVideo. Also, sometimes there is a menu setup in your monitor where you have to decide between Composite video or SVideo or Component Video, so check that in some cases as well.
Let me know what you find out.
Mar 12, 2011 | Audio Players & Recorders
No live video output on PC via composite video socket.
That's only for playing back videos you shot on the camera. It doesn't provide live view to an external source.
Jan 29, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Video camera HELP!!!!!!!!
gary Unfortunately you will not be able to do that. your video card can output to the camera but i dont think the camera has and can record video input to it over standard svideo, composite or Dv cables..I would suggest using an appropiate video screen capture program while you are playing your games and record it that way.
Mar 04, 2008 | ATI RADEON X1650 Graphic Card
Cable box pass through
ur trying to downgrade the signal when ur running composite cords u need to either run the composite out or an hdmi out to upconvert the signal the svideo cant handle the composite
Dec 18, 2007 | Onkyo TX-SR605 Receiver
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Cameras Logo
47 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
