Question about GoVideo R6740 DVD Recorder
Cannot open door
Will not respond to open/close button on machine or remote. I hear a sound as if the door is trying to open but it doesn't. I have unplugged the machine to reset it (done this a few times) but doesn't help. What else can I try? Thanks.
  • ARMPITS Jul 06, 2008
    Door will not open.
    President:
  • 4,402 Answers
Belt is loose or gear is broke, if out of warranty you can try to force it or open the cover and see if you can push the door.
Posted on Dec 03, 2007
The "custom" door on this product is poorly designed ( in the long term usage sense ) . It has a tendency to stick , especially in humid environments.
At any rate the problem can be fixed by disassembling the unit and freeing the door by removing the lite-on dvd burner from the inside . It is not particularly easy but with a little care it can be done .. If you try to pry the door open or break the outer door off it is very likely you will also break the dvd burner .
I personally left the cludgy outer door off . it doesn't look great but it works again .
Posted on Aug 02, 2008
Merlin M802 remote not working it has a new battery and the red light flashes when button pressed but won't open or close the door
need to reprogram it to the opener. push the 'learn button' then push the remotes button. door should then respond.
Dec 22, 2015 | Building Materials
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Keyless entry remote
Try this, it works on several 2002 models:
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Jun 20, 2008 | 2002 Mazda Protege
Garage door opener
Pop open the cover and check for loose wiring. Also check to see if the capacitor is still good that powers the motor.
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
GoVideo R6740 DVD Recorder Logo
182 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
