This is an indication of start-up problem in the power supply section. This is caused by leaky/dried electrolytic capacitor in
that section. It will drop the supply from normal voltage and
will disable the unit. It needs a little warm-up to make itself stable but the
symptom will get worst. Sometimes it has a bulged/dome at the top but not all, it is better
that you have a capacitor
checker/tester to determine
its condition. Your unit will back to normal again if the leaky capacitor is
isolated. If capacitor checker is not available replaced all electrolytic cap in the output of the power supply. Involved working voltage is the 10v/25v/35v, if you found this in that area replaced it all.
Another option is to look for a shop that will repair the power supply board only since the affected parts is the cap only, no need to bring the entire unit, this will saved you some money...
If shop is not available and you can't troubleshoot the board click this link http://shop.ebay.com/i.html?_nkw=TH-42PZ80U&_sacat=0&_odkw=Proscan+19LA25q&_osacat=0&_trksid=p3286.c0.m270.l1313 for the replacement.
If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to troubleshoot the problem. Don't
attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored
electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty,
avail it because the manufacturer of your unit will fix it for free. Don't open
the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
