Question about Kenmore 24902 Top Load Washer
Kenmore 80 series washer
I recently moved into a new house and in in short distance of travel between houses something went wrong. my washer will work fine as far as fill up, but it does not turn. i here the motor kick in but there is no movement. i dont hear any grinding, or any other rough type noises. only as if the motor is spin freely with a little friction. cant really diagnose when looking at it from the bottom, not my area of expertise. please help, wife is going crazy.
-Bryan
    Genius:
  • 1,224 Answers
Sounds like the joint coupler is broke from motor to drive simple 5 dollar item and about 1/2 hour labor to replace its a do it your self job easy to replace but heres another problem that i ran into before you got some material stuck in the water pump that could be the whole problem sometimes people pack washer above the tub then it goes into the water pump
i pulled out my girls sock out of the water pump easy fix tip up washer put something under washer so dont rock foward pull off hoses and then water pump look inside if theres something stuck in there use a pair of needle nose pliars to pull out easy then put back together
Posted on May 07, 2008
Kenmore washer
most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
Jul 14, 2010 | Kenmore Washing Machines
Kenmore 80 Series Gas Dryer wont turn back on after blowing fuse
Good day,
First, reverse the washer and dryer plugs in the outlet.
If that works, then the outlet needs changed.
If not,
The light switch is hot wired to the light circuit. Which means, if the machine is plugged in, the light will work.
Two possibilities.
1.The cord is bad, and needs replaced.
2. The light switch, which also runs the circuit to the motor is bad.
To access the switch, remove the lint filter, remove the 2 screws under it, then with a screw driver, pry up the top lid, one side at a time.
Lift the lid, but do not go above vertical. You will see the switch, and how to remove it.
You will need a VOM meter to test these items.
As well, make sure the machine is unplugged.
The following clip, at the beginning will get you started if you have to access the switch.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 19, 2009 | Kenmore Dryers
Kenmore 80 series dryer no work
bypass door switch , if that doesnt work and you have replaced start switch already. then i would unplug unit remove back panel and look for the blower housing , on the blower wheel housing or to the right should be a white thermostat with 2 wires going to it.round shaped and it mounts to the blower housing by pass it and it should work however dont leave it bypassed. hope this helps
Sep 19, 2009 | Kenmore 60832 / 60834
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 BALANCING PROBLEMS
The only thing I can suggest is to make sure the load is evenly distributed around the circumference of the tub. If you do only light to medium loads, this can occur from time to time. Lift lid as the unit goes into the spin cycle to check. If it is evenly distributed, you may have a support problem.
Jan 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Kenmore 80 series washer model #11092587210
Almost sounds like a timer or timer motor problem.  Could also be a loose wiring harness around the timer.  When you said it when into spin, but the next day, did the timer move at all during the "break".  Usually, a lid switch will give off that "tell-tale" clicking sound when lifting the lid.  See if it makes this noise, but it really doesnt sound like a lid switch issue.  Really sounds like a dead spot, or spots, in the timer.  Let me know.  Jim
Oct 05, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
