Question about Sansui VRDVD4005 DVD Player/VCR
Transfering vhs to dvd
It will record for about 25 to 30 min.then go to prosessing --it will not start record or play back or finalize--it is frozen--only way to remove dvd is to cut the power
  • 3 Answers
Is the vhs tape copy protected? I think you can only copy your own vhs tapes or what you record on tv. I could be wrong though.
Posted on Jan 01, 2008
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I just recorded a dvd from a VHS to DVD. It will play on my DVD but no others. I followed the instructions in the manual. I noticed a section called finalize. My question is do i finalize the dvd before i...
now that the transfer is done, put the DVD back in and run through the menu options to finalize. If automatically finalizing is an option, you could do that next time you transfer a VHS to DVD. But this first one you can finalize after the fact.
May 15, 2011 | Toshiba D-VR4 DVD Recorder/VCR
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to finish a transfer from VHS to DVD?
When you finish recording from VHS then press Stop on dvd recorder and finalize dvd, this option would be available in dvd menu.
After finalization, that burned dvd can be playback on any dvd player.
Apr 19, 2009 | Televison & Video
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
Nov 21, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
