Question about Dell 924 All-in-One InkJet Printer
Printer carrier jam
How do i fix this printer crunking problem?
says carrier jam
  • blakjam Dec 19, 2007
    I have a Dell All-In-One Printer 944 And it says clear the carrier jam. How do I do this?
    Genius:
  • 1,003 Answers
Rub your finger across slider bar big silver rod that the ink carrier rides on if it feels dry turn power off then lubricate the slider bar with a lightwieght oil like clipper oil or 3 and 1 oil.
you apply a couple of drops to the top of this bar then turn power back on this should cure your problem
Posted on Jan 07, 2008
Carrier jam on lexmark x5070 how do I fix it or clear it?
We apologize for the inconvenience. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover to access the cartridge area. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  2. Remove both cartridges from the printer.
  3. Check the cartridge area and make sure encoder strip is not loose. The encoder strip is transparent strip located behind the cartridge carrier along with the carrier belt.
  4. If encoder strip is properly seated in the printer, close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert one cartridge first. Close the printer cover and check for any errors. The carrier jam could be due to one of the cartridges.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, try to print again to verify that the carrier jam issue is fixed.
We hope this information has been helpful.
Oct 11, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Carrier jam
To fix the carrier jam, open the printer cover. Remove the cartridges from the carrier. While the cover is open, check inside for any loose transparent strip - the encoder strip. The encoder strip ensures the proper mechanism of the carrier on the assembly. If everything looks fine inside the printer, close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and make sure they are properly inserted and secured in the carrier.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
I Got a dell printer and i don't know what to do and in the printer it says Clear Carrier Jam
Turn the printer on.
Lift the lid to expose the print-head mechanism.
The "carrier" is that part of the mechanism that moves the print-head across its range.
Something is physically blocking, or "jamming", that carrier.
Feb 25, 2011 | Dell V305 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Need to fix a carrier jam
you have to open the printer and check for any parts is struck or dislodge
Jun 23, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam
i had the same problem and i'm almost positive it's because i do not have a color ink cartridge in my printer. i called the technical support and they said that both ink cartridges have to be in the carrier for the printer to work. even if one of them does not have ink in it. hope this helps. (for me too)
Dec 18, 2007 | Dell 924 All-in-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Carrier jam
Hi, Open the Top cover so u can see the cart carrier. There should be a thin translucent tape. If its snapped out then ur printer is defective. If the tape is still present in the printer and attached from left to right, then make that strip pass "behined the cart carrier, in a small slit". Then u wont have cart carrier jam. If it still persists then printer is defective.
Sep 29, 2007 | Lexmark P6350 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
82 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
