Hi all - I have a Western Digital 500GB MyBook external drive (not sure
of model, but it's black with a blue circle/light on the front - hth)
that will no longer mount on my MacBook Pro. I used it successfully for
a year or more, but it's now just an expensive paperweight. It fires
up, lights up, spins, etc. but my Mac no longer recognizes it - doesn't
show in Finder or Disk Utility.
This problem started a couple weeks ago - the first sign of trouble was
that the disk would randomly unmount and I'd get the error msg, "You
must eject this drive before disconnecting it ... " I could unplug the
power and USB cable and it would re-mount, but then would disconnect a
while later. That went on for 10+ days or so - now I can't get it to
mount at all ...
Any thoughts/help on this would be appreciated. TIA!
Have you tried it in another computer? I think these kind of problems can sometimes be caused by USB voltage problems, especially if your MBP has an old battery (I believe the battery is used as a power buffer to keep size of transformer down). If that doesn't work, see if you can find someone with the same HDD power supply and try switching that over. Failing that it's data recovery, you may be able to do this yourself by switching the actual hard drive into a new enclosure.
Was this helpful?
Yes
No
Popular Solutions for Western Digital 500GB My Book
I have a laptop to repair the harddrive was pulled off with the sata port that goes solderedto the...
(More)
I have a laptop to repair the harddrive was pulled off with the sata port that goes solderedto the mobo, there is no damage to the mobo the machine is a gateway md2614u where can i buy that sata port to re solder it to the mobo.
hi i got an wd 500g an im trying to fix bad sectors but, i ran the program that comes with the hard...
(More)
hi i got an wd 500g an im trying to fix bad sectors but, i ran the program that comes with the hard drive and it says that there are too many bad sectors and failed the quick test an extended test.do you know what can i do to solve the problem???thanks
My Western Digital Elements 1TB external hard drive will not turn on. I first safely removed it from...
(More)
My Western Digital Elements 1TB external hard drive will not turn on. I first safely removed it from my PC and unplugged. I later plugged it back in and it won't turn on. I've tried it on different computers and nothing has happened.Why won't it turn on?
i unfortunetley drop my hard dive but it was not a hard fall or drop, but now my computer will find...
(More)
i unfortunetley drop my hard dive but it was not a hard fall or drop, but now my computer will find the that there is something plug in the usb slot, but on my compter it does not recognise. my hard drive will make a buzzin sound for three or four times, then goes silent. please help thanks jake.
