Question about Belkin F1DL102P 2-port KVM Switch
New Computer Won't Switch Back
I have had a two PCs hooked up to this KVM switch one of the computers died so I bought a new one. Since I have hooked the new one into the switch I can switch from the existing computer to the new PC I installed, but the new PC doesn't switch back. My shortcut key is scroll lock twice then down arrow. It will only switch back using the shortcut when I shut the new PC down. Both are sharing a PS/2 Keyboard.
  • Scott Calafiore Dec 03, 2007
    As far as I can tell that functionality is not available
    Sniper:
  • 65 Answers
You should be able to press Scroll Lock twice and then the up arrow to go back. Have you tried that?
Here is a link to the original manual http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f1dl102p.pdf
Posted on Mar 20, 2009
    President:
  • 4,402 Answers
Can you reprogram the KVM switch to use different keys?
Posted on Dec 03, 2007
  • Cary Farah
    Cary Farah Dec 03, 2007
    can you try a different keyboard or use keyboard on both for testing?
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
I just buy a new computer and go to hook up my KVM switch that I was previously using and was working flawlessly. All cables are connected (KVM PS2) except the KVM video cable to computer # 2. So I'm...
I would look first at rep;lacing the cable itself, KVM's usually last a very long time. Cables can break down after awhile. The easiest way to check is to try the other cable on the new machine., or a pin could be bent on the cable.
I would look at those two things first before the KVM. IT is possible that the KVM may not support the new machine, depending on how old it is.
Jan 18, 2011 | Belkin 2640-FTUA 2-port KVM Switch
When 2 pcs boot at the same time on my GSC1464 switch, the one which the swtich's tune too work the video display like it should but the second limit the second computer (the one who wasn't selected) limit...
When a computer first boots up the video card send a request to the monitor to find on what resolutions the monitor supports. If the video does not get a response the card will default to very low resolutions. The only way to avoid this problem is to boot your computers one at time and keep the KVM on the computer until it fully boots to a desktop. This will allow the KVM to pass the monitor information to the computer.
Jun 29, 2009 | IOGear MiniView DVI KVMP Switch GCS1764...
GCS62 - both computers must be on for this thing to work?
It seems that you KVM switch is not working properly. computers connected to a KVM switch are not dependent to each other. you should be able to work on any of your computers while the others were turned off.
Jun 06, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Scroll Lock doesn't work /BELKIN 2-PORT KVM SWITCH
What operating systems are these? Have yout ried hitting scroll lock 4x instead of 2x?
What brand/model of KVM are you using?
USB or PS/2?
Apr 29, 2009 | Belkin F1DK102U 2-port KVM Switch
Inland ps2 kvm switch
The control for Inland KVMs is ScrLk + ScrLk + #. Example: ScrLk + ScrLk + 1 gives you the first attached computer, ScrLk + ScrLk + 2 gives you the second.
Apr 10, 2009 | Inland 08216 2-port KVM Switch
Iogear KVM Switch Not Working at All
jerk_shop is correct, the GCS632U does get the power it needs to function from the USB ports of the computers it is attached to. Make sure the USB portion of the KVM cable is plugged directly into a computer without the use of any USB to PS/2 adapters. You will also want to make sure that at least one computer is turned in order for this KVM to function.
Dec 09, 2008 | IOGear GCS632U 2-port KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
Kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Aug 31, 2007 | Belkin F1DL102P 2-port KVM Switch
Belkin F1DL102P 2-port KVM Switch Logo
332 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
