Question about Zenith R56W36 56" Rear Projection Television
3 COLORS Hi there I have just moved my tv and now I am getting 3 colors on the screen ant the pic looks like a 3d image. I am no longer available to switch to the panorama view.
  • angelwingz Jan 06, 2008
    I have the same problem with the 3 colors and how would it get fixed?
    President:
  • 4,402 Answers
You have a loose connect on the convergrence board i would not recommend running till it gets fixed
http://www.digitalhome.ca/forum/showthread.php?t=21847
Posted on Dec 03, 2007
The color is bliry and faded . if it is a night scene the picture is really dark you can hardley see anything, depending on the pic. if a pic is blue all u see is blue. it is also bright
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2011 | Philips 50P8341 50" Rear Projection...
Double images purple and green. try to convergence lines are lined up but there is a wiggly green vertical that won't move.
  • Screen looks 3D
69189a5.pngSOLUTION
Apr 11, 2011 | Hitachi 43FDX01B TV
I have a philips projection TV and it looks like a 3D screen without the 3D glasses. I tried converging the red & it is aligned with the cross hair. The blue convergence does not move. What can the...
  • Screen looks 3D
69189a5.pngSOLUTION
Apr 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
Image curves outward toward corners of screen and convergence of colors separates as you get farther from center
  • Screen looks 3D
69189a5.pngSOLUTION
Mar 06, 2011 | Sony KP-53XBR45 53" Rear Projection...
There is an arcing bow across the screen and image, text doubling in red and green, images look like an old 3D comic print.
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 06, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Green horizontal convergenc eline appears low no tin themiddle of the screen. Cannot get the adjustment to move the green line. Is something locked? Why can I not move the line to the liddleof the...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 29, 2011 | Panasonic PT-56WXF95 56" Rear Projection...
Cant get the blue convergence to move on tv, has a bad blue shadow
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Samsung PCL5415R TV
The picture is offset far to the left, leaving big black bars on each side. my remotes no longer are able to move the screen manually. I tried to unplug the tv for several hours to reset it and it didn't...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Rca r52wh74 projection 52" tv
Convergence in this unit can be one of 3 possible boards. can you adjust any ...do the crosshairs move in customer setup convergence menu
Jan 04, 2008 | RCA HD52W58 52" TV
Zenith R56W36 56" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
