Question about AudioBahn A1300HCT Car Audio Amplifier
No sound out of subs
I have an audiobahn a1300hct amp with 2 infinity kappa perfect 10" subs hooked up in a 2 ohm load. My HU is a pioneer 8500. My problem is when I turn on my HU i hear a pop from my subs and that is it. This happened once before and after a couple of days the amp started working fine again. I've tried everything I changed my fuses re did my ground cable which is now 2 gauge and I'm running a 4 gauge power cable. This didn't solve my problem. still no out put. I checked the rca cables and i did get a signal out of them i tested them with a DVOM. Remote power wire is also good. I don't want it to be the amp but I fear that it is. Any help at all would be greatly appreciated!
  • brian42177 Dec 04, 2007
    I tested the subs and they are reading 1.8 to 2.1 ohms there fine. The ground is reading .2 so that is fine also. If the amp is no good I'm thinking of upgrading to an Audiobahn A1500HCT. My subs are rated at 350rms and I know this amp puts out more than that but I can adjust the gain accordingly. What do you think? How reliable are Audiobahn amps? Did I just get a bad one. It is about 2years old. Any other suggestions. Also its in a 2004 dodge ram quad cab with the diesel. The alt. is putting out @ 14.7 volts and it has 2 batteries.
  • brian42177 Mar 09, 2008
    well i got the amp to work again good as new. The problem? The led lights that are on the sides the 4 of them. the insulation wore off one of them and caused my amp to short out. I wonder if this is audiobahns way of trying to get you to buy a new amp. I removed the leds around the outside put the amp back together and it booms. Anybody know of any 10" sub that is louder than the infinity kappa perfect? thank.
    THE AMP IS FIXED!!!!!!!!
  • 33 Answers
Check the ohm of your soeakers again. If it doesn't say 2 ohm thats the prob. Keep in mind that 2 ohm can be any where from 1.7 too 2.3 but any reading on you DVOM that gives you two decimal places is also wrong. i.e. 2.17. This would mean that you have a woofer shorted.
If thats not it and you have already fixd a ground then use your meter to check the ground; to do this set the DVOM to ohms and touch one lead to a true gound, by that I mean scratch the paint and primer off of a spot you can hide untill you see bright mirror like metal. Then disconnect the ground wire from the amp and touch the other lead to it. You should read anything from 0.3 to 0.1 any higher and your ground isn't that great.
If thats not it, The only thing left is to hook the amp up out side of the vehicle away and not connected to ANYTHING that has to do with the car. Get a battery and a diskman or a playstation, anything that can pass sound out of RCA's (Maybe even a diff radio if poss). Hook it up. If it works its in the car and let me know. I'll tell you some more to check, If not its the amp. Good Luck
Posted on Dec 03, 2007
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
I have a 500/1 Slash series amplifier hooked up to a pair of 12" infinity Kappa perfects. I have a factory dash unit still in a 2007 Lincoln MKZ so im using the converter that converts the speaker wire to...
What may of happened if that you got the lacquer finish on the electromagnetic wire to heat up and come apart. At low volume they will still have an electric connection. Because the wire physically came off from the inner housing of the voice coil it is in contact with the side wall of the speaker magnet and is proned to causing a short between coil sets. Your probably running subs with a 4 ohm impedance and when your coils short it acts more like a 2 or 1 ohm speaker. This is similar to whats called a dead short. Since the Independence is dropped to 2 or 1 ohm it is the resistance equivalent of having 2 or 4 subs attached to your amplifier which caused the final transistor bridge to heat up and it can get hot almost instantly. Check your amps outputs individually on a single speaker that you know works perfectly. If your amp does not trip the thermal protection you most likely cooked a speaker beyond usable condition.
May 24, 2010 | Jl Audio 500/1 Car Audio Amplifier
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
I need to hook up two audiobahn A1200Q subs to a A1300hcq amp
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 17, 2009 | AudioBahn Car Audio & Video
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Ok, I have a pair of infinity dual voice coil 12" subs, and a pair of audiobahn quad voice coil 12" subs. Boths sets of speakers can handle 450w. Which set of 12's would be best to hook up to this amp, and...
i recomend you just use the best single woofer in a well built box and that will give you better sound at lower gain volumes it sounds like you have too much junk laying around but to get good bass run your sub at 2 ohms if the amp is stable at that impedence
Dec 16, 2008 | Phoenix Gold Xenon-200.4 Car Audio...
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
AudioBahn A1300HCT Car Audio Amplifier Logo
302 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
