I have a LG LHD45 EL dehumifier, which I purchased in Feb of 2008. I run it 24/7, and it is hooked...
(More)
I have a LG LHD45 EL dehumifier, which I purchased in Feb of 2008. I run it 24/7, and it is hooked up to my washtub to drain. It worked fine until it just shut down the other day. I have no fan, no lights, no anything. The filter has been cleaned, and the coils look clean. I checked the outlet it was plugged into, and that is working with other appliances. Can you give me some idea as to why this happened. I am thinking it should have lasted longer than this.
Thanks so much
The coils iced up. Now the unit is cycling strangely. Sometimes the compressor won't come on. Other...
(More)
The coils iced up. Now the unit is cycling strangely. Sometimes the compressor won't come on. Other times, when you remove the bucket to empty the water, the fan will come back on but the compressor won't. Also, only the two sets of coils in front seem to be cooling.
i have 4 ea new lhd659ebk dehumidifier and they make lots of noise and vibrate a bit, this is normal...
(More)
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
