Question about Pioneer Audio Players & Recorders
Pioneer PD 8700
The lense of the player fell off. I meticulously and carefully glued the lense back on and to my amazement the player played the cd first time. I switched power off put the lid back on and powered up only to find the unit would now not recognise or read the disc. I hope vapours have not caused a problem but I did place a very tiny dab of glue at the edge of the lense holder. It may have moved while it was drying? I have now stopped as I need professional advice on how to deal with adjustments that may be needed.
  • Pioneer Master
  • 5,318 Answers
I think you are right and glue has got on the lens blocking the reading of the disc. If you can remove the glue without scratching the lens, it should cure it. Otherwise you need a new lens.
Posted on May 19, 2017
  • 3130 Answers
SOURCE: How to put the spring in
are you saying the spring to the door fell out and this is the second time??? how was it replaced the first time as a spring should not just fallout unless its dropped and a boss is broken off. ( a boss is a small plastic piece that would hold the spring in place.) This is a hard call unless you get the mechanical diagram as I dont have and they are all made differantly.
Posted on Mar 24, 2006
  • 2130 Answers
Are you using the car adapter or batteries? Are the batteries good? Are the CD's clean? Have you tried the CD's in another player? Do they work there? Maybe the lens on the laser needs cleaned.
Posted on Jan 18, 2008
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Posted on Mar 06, 2008
  • 1512 Answers
SOURCE: Pioneer PD-206 wont power up
Hi tfulton
Try disconnecting from the power and powering it up again to reset the unit.
If it still wont cooperate, the unit will have popped a IC protector in the power supply. Not an uncommon fault. The burnt disc you used may have pushed the tracking servos a little hard and a circuit protector has kicked it. Pop the lid off and look for a black 2 wire device about 4mm across that viewed from above has a D shape. Measure it with an ohm meter....It should read low ohms, if it does not... it has failed. It may be marked as ICPxx(from memory)
A fast fix we used for this is to grab the device and give it a 200 deg twist to short the legs together. Soemtimes(often) the body of the device will break off, just solder the legs left behind.
They have a habit of failingl with no reason, and shorting across them will not affect the operation of the unit, nor put it anything in jeopardy.
OR pull the board out... and replace the device, although I can tell you through experience, they may fail again.
Good luck, if you have any questions, just get back to
me here. :)
Posted on Mar 08, 2008
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
Will a pioneer pd-f605 play mp3s
Yes is will. You need to attach the MP3 to one of the inputs and select that input to play it. A burned CD should work just fine.
May 12, 2016 | Pioneer PD-F605 CD Player
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
Sep 25, 2010 | Pioneer PD-M403 6-Disc CD Changer
Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Jul 14, 2009 | Pioneer PD-F507 25-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Cd player
pioneer cd players have the common problem of losing their laser lens due to the glue that holds it in place going brittle over time. try shaking the player from side to side and upside down to see if you can hear the lens rattling about. if you recover the lens, very carefully slot it back in place and apply a tiny drop of glue (NOT SUPERGLUE) to the outside edge of the lens taking care not to get any on the focus area and leave to dry. all should be well after this. i find UHU GLUE in the yellow tubes do a lasting fix but don't use SUPERGLUE as the fumes will coat the lens.
hope this helps?
Oct 05, 2008 | Pioneer PD-M423 CD Player
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
I had this same problem today.
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Feb 18, 2007 | Pioneer PD-F1009 301-Disc CD Changer
397 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
