Home | Heaters | Delonghi - Rapido Heater
Heaters
Problem for Heaters
Generic problem for all Heaters
By Gozochan on Dec 03, 2007
We've got a fairly new model. It seems to have completely packed up. Tried the fuse (external). Has anyone got any suggestions? I wondered, for example, if there is an internal fuse I should check.
The heater is quite new and I can't think why it has packed up!
Many tks
Steve
Comments:
Dec 08, 2007
- Thank you for trying to help but it seems a different kind of heater.
Ours is not a fan heater though it is an oil filled radiator type. There are no screws anywhere and I can't see how it can have a fan unit. Im not sure we are talking about the same mode.
Tks
Same Problem
Feb 06, 2009
-   my delonghi rapido blew up & fused my conservatory. it had been on for a couple of hours when a blue flash shorted out electrical circuit. we don't use the delonghi often but had sung its praises prior to this. it gives off a fantastic heat in a short perod of time.it is portable but quiet heavy to move around.
i bought it from argos november 2006 & also took out argos replacement product cover for 3years. has this product been recalled? -   Guest
Dec 31, 2007
-   heater does not heat up checked continuity and there is no cont. on main white wire from the plug to the rheostat-   purplefuzz
Solution #1
posted on Dec 07, 2007
Somewhat Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1044 votes
you'll need to take apart the heater. in back are some screws that you take out and the unit should split - front cover - back enclosure. separate the fan from the housing and blow out, brush out the junk that is blocking the heat path on the back of the heater element. then reassemble the heater. go to a hardware store and buy some poly filter media. cut a piece to fit the back of your heater and tape it in place. it'll trap airborne particles before the fan. then when it gets clogged, wash the filter and tape it back in place. its a heck of a lot easier to replace this media then having to take apart the heater again.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
how can you buy things for less than what they ask for?
Answer
What is the safest & most cost effective patio heater
Answer
Bought reconditioned fan, heating still wont work and fan seems to be on constantly though will... (More)
Answer
I recently moved into a flat and the 2 storage heaters are not working. I put the switch on at the... (More)
Answer
Hello, I have a Gloworm 15HXi that keeps cutting-out and showing `F5` in red letters. could you... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
