Question about Hotpoint First Edition WMA22 Front Load Washer
Beko wma512w front loader
Wont finish cylce washes ok but wont do the final fast spin
have cleaned filter and pump, belt seems ok only juat a year old
heeeeeeeelp
  • titchdog Dec 05, 2007
    where would i find this?
  • matty03 Dec 28, 2007
    hotpoint wma 22, spins fast when empty but when 1 heavy item in just turns slow, replaced the bushes and the belt, still the same. any ideas.
CHECK THE CONTROL CARD FOR DAMAGE OVERLOADING THE MACHINE CAUSES THE CARD TO OVER HEAT.AND MELTS THE SOLDER ON SOME JOINTS.HOPE THIS HELPS
Posted on Dec 03, 2007
My beko washing machine wont finish a full wash and the end results clothes soaking wet and suds left in drum plz help?
Usual problem pump not working or something stuck in the filter and pump flyweel needs cleaned regularly
Sep 16, 2017 | Beko Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Wont do final spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
Gw712, clothes seem to be not spun properly and still fairly damp when the cycle is finished. they used to be fairly dry before
try cleaning your filter in washing machine,if this dosent fix problem,sounds like you need a water pump,i have had a front loader for 8 years now and had the same problem,with me finding the filter with alot of cloths lint,and other things it was stopping the water pump from pumping out water,try cleaning first and checking water outlet hose were water is pumed out might be blocked with a coin,these few steps before you spend money on water pump.
hope this helps you.
May 03, 2011 | Fisher and Paykel Washing Machines
I have a GE front loader, about 4 years old, it seems to be stuck and won't even if unpluged and let sit awhile resume normal operations when plugged back in. It indicate no specific cycle, sounds likes...
Sounds like it is trying to drain water. Pump filter is probably clogged. Washer wont work properly if it thinks water not draining all the way. Pump assemblies usually are at bottom behind lower front panel. Remove pump cap and filter, clean and reinstall. Should solve problem.
Feb 01, 2010 | Washing Machines
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE3t washer not working properly
ok lets see here im onthejob,,i take it that cycle stops with suds..ok first are we using he or low sudsing detergent,,,next when you clean pump filter did you check pump wires for defectives,,,try and bleach unit out to get rid of slugg...also check connection to pressure switch,,and ccu...keep me posted..onthejob
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
