Question about Synology DS-107 - Disk Station Network Attached Storage Enclosure with Windows ADS (Hard Drives No (DS107)
Cannot access drive, top light blinking orange below 2 lights are greenbottom light off
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Jun 25, 2011 | Office Equipment & Supplies
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
3. Release RESUME
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
The printer flashes orange light five times, and green once
3. Release RESUME
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
My hp laser jet 1300 is blinking orange and cant print please get me a solution
The flashing orange light is a basic attention light. Check the following:
1. There is a known good toner cartridge installed
2. There is paper in the tray
3. The long tab on the top of the inside of the cartridge access door is not broken
4. Connector J210 on main board is intact, tight and all 3 pins are present
5. That the drum drive engagement is working properly and the contact is present
6. The main motor connector is seated tightly
Jul 09, 2009 | HP LaserJet 1300 Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
Synology DS-107 - Disk Station Network Attached Storage Enclosure with Windows ADS (Hard Drives No (DS107) Logo
352 people viewed this question
Top Synology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Synology Computer and Internet Expert? Answer questions, earn points and help others
