Question about GE Profile Prodigy WPSE4200A
Washing Machine GE Profile/prodigy
The washing machine will be on and running normal for a few minutes and then the washing machine will begin to turn off and on, it sounds like a breaker is turning off and on. To stop it, i turn it off, lift the lid tried resetting it, close lid turn it on and it run again normally for a few minutes , and then it starts switching on and off agian. help!!
  • Anonymous Jun 10, 2008
    Its on for a little bit and resets it to a different setting (whites , large loads , med. soil an hot cold for temp and start button blinks..
  • dennis150 May 11, 2010
    How do I rest this Ge Profile .Prodigy washing machine ?? Everything works great right up until it gets to the rinse cycle and the pump does not turn on. check pump and it is working. just not whe it runs through the cycle. Is there a reset function to fix this?? Thanks
    Sergeant:
  • 264 Answers
You have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
Posted on Jan 07, 2008
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
GE Top Loader Model WASE422OAOWW Profile Prodigy
you have a motor issue, do not run the machine. ther is a risk of fire.
May 26, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy Machine not agitating
If the motor runs when it is suppose to be agitating, but the agitator does not move, pull the agitator straight up and out of the machine. Sometimes this is difficult, but you can slip a belt or similar object under the agitator, attach it to a broom handle and yank up on it. Now take the bolt out of the agitator drive collar and remove it. If you can not turn the splined transmission shaft with your fingers you are in luck and should be able to just replace the can shaped agitator drive spline. (part number WH49X10042 ) If you can turn that splined shaft with your fingers you are looking at a new transmission.
Nov 11, 2008 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Will not start at the beginning of a cycle.
replace timer this should take care of problem
Jan 23, 2008 | GE Profile Prodigy WPSE4200A
Washing Machine will not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Jun 11, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
245 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
