Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher paykel dd603
Getting a u1 error code on display after machine is running for a few minutes. Checked water supply, drain, screen, rotor, and all look ok. HELP PLEASE>
  • 1 more comment
  • Ho Daddy Dec 03, 2007
    This problem is with the top drawer. Do I still pull bottom one or what. Error code u1 is a fill fault.
  • Ken Mac Nov 08, 2008
    I have same problem with the top drawer - any solutions ?
  • tina thoc Jan 25, 2009
    Exactly the same problem with a single drawer machine. Though it is U1 eroor - not F1 error as suggested in the answer
    Problem Solver:
  • 17 Answers
Pull the bottom drawer out !!!!! To do this on the left and right sides of the bottom drawer you need to pull the pins (Plastic) then pull it out it has hoses still connected pull out and turn on side look in the back left corner (with Pwr off) there is a board there and it has a water (Flood sensor) on it make sure it is dry this is what the Fault code is
Posted on Dec 03, 2007
What is a U1 code
U1 is a filling fault , so you will have to check the water supply into the dish draw is turned fully open and the hose is not damaged or kinked . Ensure the spray arm inside the draw is free to rotate and clean out the strainers inside as well .It would also pay to check the levels on the machine .If you run the dishwasher whilst using water else where the water pressure may also be dropping to much or even changes in temperature may effect it .
Good luck
Aug 29, 2014 | Fisher and Paykel Dishwashers
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
MY FISHER AND PAYKEL DD603-SS BOTTOM DRAWER IS NOT DRAINING. HOW DO I FIX THIS?
Do you get any error code on the display?
Does the cycle complete or dishwasher keeps running?
Do you hear the pump trying to drain?
Is it happening in all wash cycles or some?
The easiest thing to do is to check if the filter at the base is clean.
I am assuming the kitchen drain is clear because the other drawer seems to work normally.
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Fisher and paykel dish drawer
U1= Machine has failed to prime with water within
approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The Inlet Valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
Jun 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
991 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
