Television I am getting a steady yellow liight indicating room temp. to hot ,but it has great ventilation & roomtemp 70degs. after awhile, the light goes off, but seem to be taking longer for it to turn off. some times it does not turn off at all, and I have to turn on & off the tv.untill it resets. I am looking for help on this matter rather it being a tech. or tv repair tech. in my location.
  • RestlessinTX Jan 08, 2008
    I have a WD-65732; room temp is 76C and the yellow indicator shines steady; when the TV is turned on, the following message to the effect "TV will shut down in a few seconds; check for airflow problems" appears; TV is just over a year old
  • 4,402 Answers
You have an internal heatsink that is over heating. my guess would be convergence IC
Posted on Dec 03, 2007
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
PS3 won't stay powered up.
powersupply is bad. ebay has them for around 45.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Flashing Temp indicator light, after 5 min on a cool morning
Its a Low Coolant indication. Fill the reservoir to at least the MIN level.
Jun 02, 2009 | 2002 Volkswagen Cabrio
2000 hyundai elantra inside room heat
Almost every car(including yours) has a flow through ventilation system which means even with the air turned off air will still come through the vents. Its hot because of outside temp and engine temp.
Basically just push the recirculation button and it will stop.
May 18, 2009 | 2000 Hyundai Elantra
No more hot air
it is full antifreeze .is the temp gauge at operaiting temp. if not put a t-stat in the car.
Jan 22, 2009 | 2002 Dodge Caravan
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
no. this is not normal. this type of problem can be dangerous to keep in your house. you should get the device replaced right away.
Jun 26, 2008 | Philips DIRECTV H20 DTV Receiver
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
