Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
51'' black line comes & gos
  • baiello Jan 01, 2008
    picture has a rainbow color and the picture looks warped or bent
  • Anonymous Mar 19, 2008
    I Have a Apex Projection TV model # GB5108. I has black bars that appear across the screen intermittently after about two to three minutes of operation. I changed two bad capacitors, one in the power supply and one in the vertical circuit but that did not fix the problem. Also the convergence is off. The green in the middle of the screen and the red at the bottom.
    Any Assistance would be greatly appreciated. My e-mail is emkbowl@hotmail.com
Mine is doing the same thing, l have been told it is the verticle IC
Posted on Feb 05, 2008
..Computer screne is black,,d sub comes up and
Huh? D-Sub is a connector? If you plug an external monitor into it the laptop is probably designed to shut of the internal screen. If this is not what you mean please get someone who can write a functional English sentence to clarify your meaning.
Sep 21, 2014 | Computers & Internet
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
D sub comes up and screne gos black.shut screne off and put screne back on and d sub comes up again and gos black again,,what is the cathold and drivers in the answer I got before.is it something I can...
It sounds like you have not selected the correct INPUT to the device.OR not connected the cable correcty to the input.
Check your user manual for the device.
Sep 21, 2014 | Cars & Trucks
There is a 4 inch wide line across our 51 inch plasma tv. is it fixable
Yes the board to repair is cheaper than tv. As well you can search youtube an get info on how to do it your self. I do my repairs.
Mar 24, 2014 | Televison & Video
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Rear projection sony 51", comes
Sounds like bad picture tubes. please post a model number, also are you seeing arched lines going through the picture? these can useually be seen best on a blank input wiht a black background.
Thank You
Tim
Sep 11, 2008 | Televison & Video
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
51'' projection tv black line comes and go
It's because a phone or computer is right beside it, interfearing with your connect, which means you have cable or satilite, just move the celluar/house hold phone and or computer
Nov 29, 2007 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
51 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
