Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
I have a gas furnace and central ac.
My old thermostat could be set at 15 degrees (c) and would only shut off the furnace at 25 (c), so I purchased a programmable thermostat to replace the old one (thinking that it must be broken).
Now the new thermostat won't shut the furnace off at all. I can set it at 19 degrees (celsius) and It will keep heating to 30 (i didn't let it go any further).
Is this a furnace issue or a thermostat issue? could i have improperly installed the new one? there were only 4 wires red, black , white, green. I had an old honeywell thermostat and now a new one the wire hook ups were pretty simple looking (red to R, green to G, black to Y, white to W)
pls. help!
Bronwyn
  • kkaa Feb 11, 2008
    My honeywell prgrammable has been fine for 4-5 yrs. It has started to turn off the furnace before the set time, or not turn on at the time set. I took the batteries out, turned off and then reset times. It started turning on in the a.m. then turning off 3 hrs. before set time in eve. What now??? or next?
    thanks,
    k-avila@msn.com
  • ATITELMAN Sep 01, 2008
    HOOKED UP MY THERMOSTAT - WON'T TURN ON - THE ONLY THING i FOUND I COULD HAVE DONE WRONG WAS USE THE RED WIRE OR PUT THE RED WIRE IN THE WRONG PLACE - IT HAS TWO HOLES FOR THE RED PART THAT ARE J0INED BY SOME SORT OF WIRE THING - I PUT MY RED WIRE INTO THE FIRST HOLE - WAS THAT RIGHT? WHAT ELSE COULD THE PROBLEM BE?
Our Honeywell thermostat is model RTH6300B. Now that the weather is getting hot, we decided to put the centeral air on. Hot air keeps blowing out. I called Honeywell several times thinking that we had fixed the problem. It still is blowing out hot air. Also, my husband checked the wires. Has anyone else had this problem? Any ideas what it could be?
Posted on May 29, 2008
  • Hal Taylor
    Hal Taylor Oct 06, 2012
    is it a heat pump? -- if so,sounds like the reversing valve is not functioning
The screen if faded on the thermostat
Posted on May 15, 2008
    Sergeant:
  • 288 Answers
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Posted on Dec 23, 2007
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
I have a Goodman central HVAC system (forced gas air and AC). I replaced the old CHT18-60 thermostat with a Honeywell RTH2310. Now the heat and fan stays on constantly (regardless if in the programed mode...
I checked the model #'s and they should interchange just fine. Double check your wiring. On the thermostat Red to Rc (which should also be jumped to Rh), White to W, Green to G, and Yellow to Y. Move T-stat controls from current position to oposite end and back to what you want to run ie. A/C if thats what you want. Move fan control to on and back to auto. (I find this eliminates some close but not quite right settings). This should work. If not look in furnace to verify how it is wired. Any colors that do not match the above will be your corrective action to do at the thermostat. if necessary change t-stat wires at t-stat to match what is in the furnace.
Dec 28, 2010 | Honeywell Focus 6300B 5-2 Days...
I'm replacing an old thermostat with a new Honeywell RTH6300B programmable. I have propane heat and central AC. My old thermostat has a black, a red and a yellow leads with no ID on the old thermostat wall...
Open up the propane furnace and see what color wires are hooked to the gas valve or circuit board. If it has a circuit board, note which color is on the R terminal and W terminal, Connect the the thermostat the same way. Most likely the yellow wire powers your A/C so you can hook that one to the Y terminal.
Nov 27, 2009 | Honeywell Programmable Thermostat Heater
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
Dec 13, 2008 | Honeywell CT3200 5-2 Day Electronic...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
705 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
