Question about Vulcan GR35 Deep Fryer
Vulcan 1gr45 deep fryer
I can get the pilot lit and to stay on but when i turn the thermostat the pilot turns off. i have put in a new gas valve and still the same thing, what do you think that it might be
  • 1 more comment
  • krisztof Dec 04, 2007
    thanks for the help it worked but i will not use hobart again nor order parts from them ive had a lot of problems with them.
  • Paul Huggy Jul 18, 2008
    I have the same problem
  • Anonymous Mar 24, 2014
    cannot find the fryer basket for Vulcan fryer model number TK65
  • 640 Answers
The thermopile is bad.You can contact your local hobart service center for the part number.Its a cheap part and easy to put on,any questions let me know.
Posted on Dec 03, 2007
Pilot wont lit
The first thing to do is make sure all the air has been purged from the gas line.
Oct 12, 2013 | Vulcan GR45 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
This fryer has been giving us problems. After we
You can try putting a jumper wire between the two terminals on the thermostat after the pilot is lit to see if the valve comes on. It is less than 1 volt so don't worry. That will tell you if the problem is with the thermostat or the gas valve.
Tom
May 18, 2010 | Dean SM20G2 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Vulcan Deep Fryer, burners shut off, remains off!
sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Dec 07, 2008 | Vulcan EF3 Deep Fryer
Wont come on
low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Aug 04, 2008 | Vulcan EF3 Deep Fryer
Vulcan GR35 Deep Fryer Logo
282 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
