Question about Yamaha R-V701 Receiver
Yamaha rx-v661 unsolved speaker wiring error
After attempting to run auto set up, unit shuts off and as I turn unit on, I get the error, (check speaker wiring) as unit is cut on. Unit trips braker of some type as it configures the volume setting on sub, after the third volume increase. I have checked wiring many times and am unable to correct so far. Is there anybody out thier? with maybe a solution thanks.
    Scholar:
  • 54 Answers
1. Try running the auto setup without the sub. ( is it a powered sub {the sub has its own amp on the back} or is a NON powered sub that is driven off the speaker jacks of the Yamaha receiver. )
If the sub is powered, and connected to the Amp via the RCA cable from the " sub out " jack, chances are you either have a defective sub or a gound loop.
Good luck...Rob
Posted on Mar 04, 2008
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Jan 15, 2009 | Yamaha RX-V661 Receiver
Subwoofer won't work after Auto Setup
hi can you try this it might work, take off all the connections to your receiver and the reset your receiver to the original factory settings then turn it off and disconnect it from the socket. connect all the the speakers and turn on and start auto set up. hope it works
Sep 12, 2008 | Yamaha RX-V661 Receiver
I have a new RX V661 7.1, shuts down when I turn it up.
How much loudness are you trying for. Also, the program material and bass/treble settings factor in when asking a system for increased power...accordianman
Jun 19, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Feb 27, 2008 | Yamaha RX-V661 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Yamaha R-V701 Receiver Logo
160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
