Question about Maytag MGR6775 Stainless Steel Kitchen Range
All 4 ignitors just stopped working on the stove top...no more 'clicking' sounds
Ovens seem to work fine (the seem to use a 'glow plug' type of ignition). Could this be the spark module? How does one replace it? Is there a service manual with a schematic diagram?
  • 22 Answers
1 Check to be sure unit is properly connected to power supply.
2 Check for a blown circuit fuse or a tripped main circuit breaker.
3 Check to be sure ignitor is dry and clicking. Burner will not light if ignitor is damaged, soiled or wet. If ignitor doesn’t click, turn control knob OFF.
4 Burner ports may be clogged.
Posted on Dec 04, 2007
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
Open Questions:
Maytag MGR6775 Stainless Steel Kitchen Range Logo
381 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
