Built in wireless lan........
Hotkey to activate built in wireless lan not working on my fujistu Amilo A laptop. Cannot connect with my router.
    Scholar:
  • 79 Answers
Operating System? Sometimes with XP, you have to disable the Zero Wireless Configuration Utility when using a proprietary on-board utility. This is done in the services.msc panel.
Start > Run > services.msc (ok)
Posted on Dec 04, 2007
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
How can I connect my kn 4035 printer to my laptop through a wireless network?
This printer has a lan connection built-in, you can connect this printer to a LAN port on your wireless router. You need to configure the IP address of the printer to work in the same IP address range that the wireless router uses so the printer can communicate with your network.
May 04, 2011 | Kyocera Mita KM-4035 Printer
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Sound and wireless problem
try to go in control panel then find the sounds and audio devies and also in network connection and if you find the 2 properties try to configure out if the sounds and network are installed properly if not installed the sounds and network connection through your installation cds
Aug 07, 2009 | Gateway M305CRV Notebook
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
I recently bought an Amilio Laptop made by fujitsu Siemens I have tried two different wireless routers and cannot get the laptop to connect with either. It does have wireless built in. What am I doing...
It might be that the Operating System is preventing connection to the router because:
  • the network is unsecured. look for the "Connect Anyway button";
  • the Amilo's WiFi is set to a manually configured IP address, pls try "Obtain an IP address automatically" in the Internet Protocol (TCP/IP) Properties of the Wireless Network Connection of the Control Panel/Network Connections;
  • it maybe that your Amilo has its own WiFi configuration and if so, you should disable the OS to manage your wireless connection.
Incidentally, you could try downloading a third party Wireless network detection software that is to verify that the Amilo's wireless card is working and that it can sense the Wireless router. An example would be NetStumbler.
Hope this be of initial help/idea. Pls post back exact model number of the Amilo laptop, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Computers & Internet
Wireless Driver for Fujistu Lifebook C220 fo Fedora 8
Does your laptop definately have a built in wireless card?
If so then the drivers for it will be on the Fujistu site :)
Mar 22, 2008 | Fujitsu Siemens LIFEBOOK C2240 PC Notebook
Wireless hotkey not working
i belive that when your computer boots you press F2 and the wireless card is automatically turned on
Mar 21, 2008 | Fujitsu (S26391-F2494-L100) Bluetooth...
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Computers & Internet Logo
331 people viewed this question
Alun Cox
David Payne
David Payne
