Slave jumper setting
Trying to move files from old PC HD (maxtor 91360u4; win 98) to new PC w/vista. The old HD has no jumper settings printed on it and I've tried every combination possible. All but one of the settings try to boot to the '98 os and end with a message about insufficient memory (not possible w/this new PC). Only one (bottom/right-horizontal) will boot to VISTA and, after it's up, I can't find the old hd listed anywhere on it (win expl or controlpanel/system files). Or, is there another, relatively easy way to retrieve about 7 gb of files?
  • 1 more comment
  • iysad Dec 06, 2007
    First timer- not familiar with site....but didn't see any solution; only a pitch for signing on for the prem assist plan; opted out & fixed it myself.
  • falert Jan 15, 2008
    not sure where to set jumper for model 904323d3 for master drive so i can use a second drive as slave
  • lubees1750 Apr 15, 2008
    how to put the drive as slave hd does not have picture
    President:
  • 4,402 Answers
Http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg
Posted on Dec 03, 2007
  • Cary Farah
    Cary Farah Dec 08, 2007
    i give you a place to look for drivers and you give me a Inappropriate gee at least i tried to help u
  • Cary Farah
    Cary Farah Dec 18, 2007
    • "FixYa!" -
      The solution provides great advice on how to solve the problem.
    • "Helpful" -
      The solution provides helpful information that helps solve the problem.
    • "Thanks for Trying" -
      The solution provides some help but does not solve the problem.
    • "Inappropriate" -
      The solution has nothing to do with the problem.
Im trying to clone my old hd to my new seagate 4oogb EID both are eid interface hds but I need to no where to place the jumper on the seagate? and when i try to clone it says unable to lock volume on the...
are you trying to do this using while using your os? if so i would try downloading partition magic, it is saying unable to lock volume because your currently using it e.g. your os is installed on the drive, and it cant lock your os when your using it at the same time.
Nov 02, 2010 | Seagate Barracuda 250 GB EIDE Hard Drive
I have an old maxtor 2 drive that i'm trying to slave
Hi!
Just follow the jumper settings in the picture diagram below:
I hope it helps..
Thank you for reaching Fixya.
Apr 11, 2010 | Maxtor Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
Connect it on hardisk enclosure then removed all pins
then connect it usb this serves as an usb flashdisk
Install old maxtor HD on newer pc, change it from mster to slave
From your own description Slave : Off therefore remove the jumpers
Jul 26, 2009 | Computers & Internet
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
1,840 people viewed this question
Alun Cox
David Payne
David Payne
