Question about Zebra LP 2844 Thermal Printer
Won't print Tried turning off to reset, but light comes on and stays orange. Can't get it to print anything! HELP!
  • 53 Answers
It could be a lid open sensor issue, if you put pressure on the lid does the light turn green? it is common for ir sensor to fade over time and if the reflectiveness of the case above the sensor fades you get this error too. the sensor is to the right of the roller and if you clean or place a sticker on the LID facing the sensor it can fix the problem
Posted on Dec 07, 2007
3 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: canon bjc 240/orange light stays on
The blinking orange light could mean one or more of the following: -Home position error -Waste ink full error -Temperature sensor error -Printing position correction error -Cleaning error -Printer memory error I would probably clean the waste ink tank first. Make sure you unplug it first. Take the cartridge out and clean real good at the bottom.
Posted on Jul 02, 2007
  • 40 Answers
SOURCE: My Canon pixma ip 4000 won´t print. The light
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Posted on Dec 08, 2009
Hpdeskjet940-c 1284-b orange light stays on flashing an it does"t print anything
Follow this blog may be it will help you.....http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00299&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=83027&lang=en
Mar 06, 2013 | Office Equipment & Supplies
Kyocera ps1010 will not print bottom orange light stays on
unplug the network cable turn machine off and then on without the cable plugged in if it comes ready your problem is the print job delete it
Feb 01, 2018 | Kyocera Mita FS 1010 Laser Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Lower light blinks on everytime I try to print anything and nothing prints
Check for any paper jams, I think the orange light mean that there is a error and therefore cant print, check incartriges and other areas inside
Apr 13, 2009 | HP DeskJet 845c Printer
Printer orange light flashing 2 and 5 times, servive error 5100
Hi You can Try 2 things.
All the luck for you
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 26, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Error e3
there's a problem with you mechanical alignment or try this resetting...
Service mode operation procedures -
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon bjc 240/orange light stays on
Jul 01, 2007 | Canon BJC 240 InkJet Printer
Zebra LP 2844 Thermal Printer Logo
400 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
