Question about JVC HD-61Z786 61" Rear Projection HDTV
JVC 61" Rear Projection HD61Z456. Need to take the front screen off.
I just brought this home 2 days ago and set it up yesterday and noticed some spots in the middle of the screen that are on the inside of the screen. Depending on where you stand the spots are black or white. They kind of look like what a sweat spot looks like after it dries on glass. I am the second owner of the tv. I bought it at AAFES for a discount because it was brought in to be repaired. Is it possible to remove the front screen off to clean it? I really don't have time to have a repair person come out. Need help because it's really driving me crazy.
  • Flying W Dec 30, 2007
    My jvc is about a year old and I have just started noticing like 2 small circular grey areas. figured it was dust on the inside of the screen but scared to open the front. I used to clean my rear projection screen, mirror and laser lens. not sure about a DLP.
  • terrydoo Mar 12, 2008
    i bought mine brand new and it had spots on the inside of the screen. i called the place where i bought it and they took it and had it cleaned and now there is wipe marks on the inside and i called them back and they told me it was my problem because jvc wont cover it. i paid $2000.00 for it and im stuck with smudges on the inside of the screen. need to know how to get the screen off so i can clean it myself...
I had the same spots on the inside of my screen. Bought mine at AAFEs also. Called JVC and they gave me the number to a local service that came out to my house and replaced the screen under warranty. The technician said it was a common problem caused during the manufacturing process.
Posted on Apr 29, 2008
I have the same t.v and problem ,and was told it is from the bulb and only gets better once it is replaced
Posted on Feb 10, 2008
    Genius:
  • 1,030 Answers
IF this is in the screen... there has been issues where the entire light engine has to be replaced...
Posted on Dec 07, 2007
I have a hole in my screen its a jvc
You need to replace the screens. Call JVC with the model# of your set and JVC will tell you the part# so you can ordere a replacement
Mar 15, 2013 | JVC HD-61Z575 61" Rear Projection...
Set turns on then turns off a few seconds later
Set have the tv projection lamp problems.Tv have a "LAMP"LED light indication on the tv front screen panel are flashing are staying on lite?Yes,than the tv projection lamp life are ending.Tv have been on and used like 4 or 5 hours a day and the tv projection lamp been on the tv like a 1 1/2 or 2 years?If it is a new tv projection lamp,than ur tv might have a problem with a board call a Ballast board.This Ballast board job are to help to ignite the tv projection lamp.
Dec 06, 2010 | JVC HD-61FH96 61" Rear Projection HDTV
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456.
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
Jun 11, 2010 | JVC HD-61Z456 Television
JVC TV: Model # HD61Z456 61 inch - what is the modet number of the bulb that I need to replace. I have no picture on my screen.
The bulb part number is: TS-CL110UAA. Take out the bulb and look inside from the front side. Visually inspect any physical damage inside. If it looks clean, lamp might be good
Jan 22, 2010 | JVC HD-61Z456 Television
Lost the original remote for my sylvania tv and the closed caption is on. how do i get this off my screen without remote?
If there is no on screen menu option, accessible from the console, that you can switch off, the answer to your
question is "You can't".....without obtaining a universal remote that you will install using the codes for the
function of your particular set, and since you have a rear projection model (61 inches, wow!!) every universal
remote normally used for the purpose of home entertainment theater setups will have the code for your set.
Enjoy!!
Apr 17, 2009 | JVC HD-61Z575 61" Rear Projection...
I HAVE A JVC HD61Z456 HOW 2 REMOVE THE LAMP
HELLO Iit can be accessed thru the front of the set. you will have to remove the screws that hold the speaker panel on the front of your set. !!! after removing the speaker panel you will see a small square box with a handle with two screws holding it on, you will have to unscrew those and pull on the handle to remove. hope this helps. "GOOD LUCK"
Aug 09, 2008 | JVC Televison & Video
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC HD-61Z786 61" Rear Projection HDTV Logo
930 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
