1994 Jeep Grand Cherokee Logo
Posted on Aug 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 94 cherokee limited 5.2 v8. which transmissions are come
I need to know if I can replace a 46rh trans with a 42re trans in my 94 jeep grand cherokee limited 5.2 v8
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 286 Answers
  • Posted on Jun 27, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
286
Questions
Helped
97295
Points
631
The 46rh is a hydraulic transmission as where the 46re is an electric transmission. With minor wiring you can replace the 46re with the 46rh but not the other way around. Your transmission would stay in limp mode and wouldn't shift out of 2nd gear. So the answer is no.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
3688
Points
12
The 42re is for the 4.0 straight 6 and the other is a v8....i usually hear this question other way around. the 42re isnt as strong as the 46 rh or e. it wont bolt up. Ive tried!@! i have a 94 with a 4.0
2helpful
Is a 1995 jeep grand cherokee limited v8 vs. inline 6 transmission interchangeable?
No sir they will not interchange. i worked at a transmission shop for 7 years. the inline 6 has a 500 trans in it and the v8 has a 518 trans in it. the bellhousings are different.
How do I adjust the bands on my 1993 Jeep Grand Cherokee Limited AW-4 transmission?
WHAT TYPE TRANSMISSION YOU WORKING ON AND WHAT BANDS ARE YOU ADJUSTING FRONT AND REAR YOUR TYPE VECHICLE HAS MANY TRANSMISSIONS 42RE , 42RH , 44RE , 46RH , 46RE, NEED TO KNOW WHAT TRANSMISSION BECAUSE EACH TRANSMISSION HAS 72 INCH LBS TO ADJUSTMENT ON BAND ADJUSTMENT SCREW BUT YOU WILL HAVE TO BACK OFF DIFFERENT TURNS ON EACH TRANSMISSION.
1helpful
Transmission filter rplacement how much fluid?
Automatic Transmission, 46RH Initial Fill..........4.1 quarts
Automatic Transmission, 44RE Initial Fill..........4.1 quarts
Automatic Transmission, 42RE Initial Fill..........4.1 quarts
Automatic Transmission, Total Fill
4 speed 44RE..........11 quarts
4 speed 46RH..........14.4 quarts
4 speed 42RE..........11 quarts
3helpful
2answers
What model transmission do I have in my 1994 Jeep Grand Cherokee , 4.0 6 cylinder, 4 X 4?
If it is automatic it could be an A500/42RH, 42RE or an A518/46RH, 46RE
If it is manual it is a 5 Speed (Aisin AX15)
1helpful
I am trying to find out what transmissions will fit my 94 jeep grand cherokee
The 4.0L six-cylinder models have either a 42RE or a 42RH transmission. The 5.2L V8 models have either a 44RE, 46RH or 46RE transmission.
How to identify... e
very trans they made and what they put them in... jeeptech.com/trans
Hope helps.
2helpful
What other yrear transmissions will fit in the 95 grand cherokee with the 6cyl besides 95?
42RE: The 42RE four speed automatic transmission was used in 1993.3 to 1998 Jeep Grand Cherokees with 4.0L engines. 46RH: The 46RH four speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines.
2answers
94 Jeep Grand Cherokee Transmission Problom
1994 is the same as 1997. parts are interchangeable
94 Jeep Grand Cherokee MY transmission went out
no it wont work.they made too many changes with them about 2 years older and id say yes but no they wont interchange
1helpful
2answers
Transmission
Transmission
Typo and model:
1.- 4-speed automatic AW-30-40 (6cil start of 1993)
2.- 4-speed automatic 42RE ( 6cil 1993)
3.- 4-speed automatic 46RH ( V8, 1993-1995)
4.- 4-speed automatic 44RE ( 5.2L V8, 1996)
5.- 4-speed automatic 46RE ( 5.9L V8, 1998)
6.- 5-speed automatic 45RFE( 4.7L V8, 1999 in WJ)
Enter the VIN in here: http://jeep.avtograd.ru/VIN/vin_en.asp
Also cHeck this info: http://www.jeep.com/en/4x4/systems_by_vehicle/
Good luck!!!
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
