Fixing my epson Acculaser C900N to my network
Could you please help me set up my printer Epson C900N to my workgroup to share the printer in our LAN??
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there!
Well, depending your LAN and Administrator services, and polices, you can install from one PC and put the printer as share. or with TCP setting and IP, for the Other see the printer on your LAN, and you must have a workgroup name, too, and the others , for them to see you.
I know is a generic solution but you got an idea.
Posted on Dec 04, 2007
Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 27, 2012 | Konica Minolta Office Equipment & Supplies
Make 2 pc's see each other
This is a common issue with XP and later versions of windows. Check that both computers are in the same workgroup.
On XP right-click My Computer, select properties, go to the Computer Name tab and check the workgroup name.
On Win7 right-click My Computer, select Properties, click Advanced System Settings, go to the Computer Name tab and check the workgroup name.
If the workgroup name is the same on both machines but neither come up in My Network Places then try changing the workgroup name to something else on both machines and restarting them, this usually clears up that issue.
If they still don't show up check that you have Network Location Awareness and File And Printer Sharing turned on on both machines.
On Win7 this is checked under Network and Sharing Center, Change Advanced Sharing Options. Make sure that Turn On Network Discovery and Turn On File And Printer Sharing is marked for the current profile (Home or Work, normally).
On XP go to Network Connections, right-click the connection for your LAN and select Properties, make sure that File And Printer Sharing For Microsoft Networks is checked. Then, go to Administrative Tools, Services and make sure that the Network Location Awareness service is running.
Both machines may need to be restarted after this, but that should fix the issue. If not, please let me know.
Jun 09, 2012 | Computers & Internet
Epson acculaser, service REQUEST E511, plz help,
check the tr0 sensor it's dirty , clean it properly. the picture below is showns the location of the tr0 sensor.
Dec 07, 2010 | Epson Aculaser C1100 Printer
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Our HP desktop and Dell laptop are both connected to a AT&T 2 wire router/modem. The desktop is connected to an Epson non-wireless printer. How can we print wireless from the laptop? The laptop is...
You have to install the relevant drivers FIRST (Just install without printer thats fine) on the host & clients and then make sure you "Share" the printer on the Host setup. (The one where the printer is attached). Then on the clients you install a "Networked" printer and "Find" it on the network. Now ALL the PC's need to be in same"Workgroup" and have "Sharing" enabled on each machine, they all must have a name & password too..
Jan 30, 2010 | Epson Stylus CX9400Fax InkJet Photo...
I can not get my nx415 to print over my home
Calvin. This setup is so old tech !
check workgroup names are the same on both computers
better setup
If it is an ethernet network
Get a usb to Ethernet print server and you can print to the printer without having to keep a receiving computer turned on .
https://www.mwave.com.au/wired-networking/print-servers-wired
Jan 25, 2018 | Epson Office Equipment & Supplies
Epson Acculaser c1100 ink blead
First rule out that it is a paper issue by trying a different type of paper
If that dosnt work
check if the gradation setting is too small when printing graphics. On the Basic Setting menu in the printer driver, click More Settings, adjust the gradation setting by sliding the Contrast slider bar
If that dosnt work
Clean the print head .
see steps at the bottom
If that dosnt work
It is starting to look like drum/photoconductor problem, this may need to be replaced (the most expensive solution)
Follow the steps below to clean the printer head.
r_1.gif Open the cleaner cover on the right side of the printer. Then, open cover A. d580095.gif
r_space.gif r_note.gif Note: r_space.gif r_space.gif Move the cleaner completely in and out. Otherwise, the printer may not be cleaned effectively. r_4.gif Push back the blue lever on the right inside of the printer. d580098.gif
Sep 11, 2009 | Epson Aculaser C1100 Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Im need help in networking my 2 desktop pcs to my epson printer
How is your printer connected? direct plug-in to your network or is it attached to a computer? If the printer(s) are both on one pc, share the printers on THAT pc and give them each a name. Go to the PC you want to share them to. go to ...printers & faxes go to>>>add a printer>>>choose NEXT, choose network printer, >>>>choose connect to THIS printer (DO NOT fill in the blank) leave it and hit next. find your workgroup and what you named the OTHER computer. open the plus-sign and choose the printer you want...move forward. Remember to SHARE on one computer ADD to the other (not share on both)
Dec 06, 2007 | Epson RX620 All-In-One InkJet Photo...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
