Question about Dell 2300MP Multimedia Projector
Connection with the TV
How to connect my projector dell 2300 mp with my TV so I could watch the TV signal by the projector?
    Brigadier General:
  • 6,966 Answers
It will work only if your TV has a Video OUT either in Composite RCA, S-video or in some other form although not all TV models have this feature.
Alternately, you can hook up your projector to an old VCR which definitely will have a Video OUT and use its built-in TV tuner. Of course you have likewise to connect a cable/aerial to the RF IN of the VCR.
Hope this be of some help/idea. Good luck and kind regards.
Posted on Dec 04, 2007
My used DEL 2300 MP doesn't seem to be compatible with my Compaq PResario CQ60. It keeps searching for a signal? Any suggestions?
Decrease the screen resolution of your computer to the minimum possible value and check.
Probably the projector does not support the resolution of the laptop. With a lower resolution it might work.
Oct 30, 2011 | Dell 2300MP Multimedia Projector
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP turns on and the lamp turns on, but then the tempera
Ok you need to replace the thermo sensor on this now the thing is the replacment is not something "just anyone can do" Now what you can do is this you can take it into BEST BUY witch are EXPERTS to help you replace the sensor in this.
But for a end user to dig inside of this would not be wise. I would highly recommend a expert fix this due to the sensor. The sensor is on the ballast board.
I hope this FREE answer helps please do vote on it anyways and leave some feedback for us today!
Mar 05, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Jan 31, 2010 | Dell 2300MP Multimedia Projector
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
No signal
Hi and welcome to FixYa,
Initially, the "No Signal" error message indicates just that, it is not receiving anything or that the signal it receives is beyond its capacity. With this in mind, pls check:
  • the cable connection from PC to Projector;
  • that the PC is set to display on a 2nd monitor, TV or Projector depending on the capability of the PC's video card (Twin View or Dual View); or
  • as main monitor;
  • lower down the computer's Screen Resolution and/or Screen refresh rate.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Dell 2300MP Multimedia Projector
Color wheel
Hi there
Simply locate your nearest Dell dealer and give them a call.
Apr 02, 2008 | Dell 2200MP Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
2300 mp stays on for only 3 minutes then turns off
ok..try to long press the power button to refresh the settings..
Jan 28, 2008 | Dell 2300MP Multimedia Projector
Dropped signal
Have you tried changing the display to clone the image?
Nov 23, 2007 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
321 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
