Question about HP cp1700 Color Inkjet Printer
Need help The printer will not print the entire design. It sometimes leaves of the bottom, or sometimes it only prints half. this is on transparency paper
  • 58 Answers
Since you are doing transparencies just make sure it is for HP also there may be a weight problem. You see as the sheet goes though it can cause a buckle to which now the print cartridge is not touching any longer.
Posted on Dec 03, 2007
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there. can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Can I print transparencies from my Canon iP1800
Transparency can only be printed by a laser jet. from a ink jet the ink will come off. you can try a photo copy machine that will work for sure
May 07, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have added a picture (done as a transparency) as my background on a calendar but when I print, the background picture does not print. How do I change this? Please help...Thanks a bunch!
You may have to adjust the transparency settings to see what the lowest limit your printer will print.
Try doing a test page with multiple images set at different levels to see which works the best.
Oct 27, 2009 | Broderbund PrintMaster Platinum Version 18
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Epson artisan 800 wont print to a transparency
OK so i tricked my 810 into printing on a transparency. NOT that I recommend doing this ... but .... I took four pieces of clear tape and taped the top (where it goes into the printer) and on each side about three inches from the top.
Then I put it in the tray with the transparency on the bottom of the paper -- since it brings it up thru the printer and flips it over, it prints right onto the transparency !!!
It didn't like it the first time, since I just folded over the tape on the end that gets sucked into the printer first. Hence the added stabilizers on each side.
Feb 15, 2009 | Office Equipment & Supplies
OHP sheet apparently jammed within the printer
There should be an access door on the back of the printer. Open it up and I think you will find your transparancy in there. If it is,, pull it out from the back door and not the front.
If you cann't see it, leave the door open, remove all paper from the tray, and then press the feed button.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Resume button is stuck
i think you have aproblim with the main card in side the printer
Jan 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
HP cp1700 Color Inkjet Printer Logo
26 people viewed this question
Ben Johnson
