Whenever i receive a msg, two msgs are automatically created in my outbox and i cant send or receive anything via bluetooth. i already tried the soft n hard format, it doesnt work.
can u hard format ur if no then do it first ( switch off ur phone hold these keys *+3+send and switch on and hold keys then whenever formatting is not started ) after format ur phone will be ok
You can't post conmments that contain an email address.
Sounds like your memory card[sd card] is failing. I would call the maker of the sd card, not your service provider as they cant do anything. or go out and purchase the same card and replace it. If this doesnt help, call your service provider and they can walk you through the step needed. You may have to do a facotry reset. Or erase some media from your sd card, not the phone itself.
Try to reformat the memory. Dail code *#7370#
I am telling this because this problem is not so rare in this model. This problem can be related with the Memory Card.
Thank you Sir, Have a nice day.
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Make sure you're using your mobile service provider's settings and msg center number, and that your setting for reply is set to: reply via same center number to; NO
hey...its very simple...go to organiser..n den to alarm...and den to once alarmand if u wanna set d alarm at 6am jus type 06:00....and if its for 6pm...set it as 18:00..and den press ok...thats yet...
yes ofcourse...u can store ur text msgs in ur outbox...firs open ur msg in d nbox and den press ok and den press send and den press d end call key(d key used which s used to end or cut d call..)..and a screen sayin save to outbox appears..press yes...thats all...
hw do u do that????
hw do u do that????
